View Full Version : Minnesota 67 Camaro Build
Bobs 67Camaro
04-18-2011, 05:20 PM
I have decided to tear apart my 67 Camaro which I've owned for 10 years, and make it handle and perform!
Previous State:
1967 Camaro SS, 350 SMC, M21, 10 Bolt.
Current State:
Chassis:
Speedtech track time package.
Ride Tech Coil overs (500# fronts, 250# rears)
ATS spindles, power rack, speedtech alum body mounts.
Torque arm rear, with ridetech coils.
Engine:
L92 which will soon receive an LS3 intake.
Still need to relocate the AC compressor
Planning to do a lumpy cam
Tranny:
6L90e 2WD tranny with splined tail shaft.
need to find a shallower pan, or modify a 6L80e G8 pan (for an extra .8" of clearance)
Still need to have a drive shaft made.
looking for a shifter, and plan to use paddles from Twistmachine.
Will do a torque converter with cam.
Rear end:
Had a 9" fab'd housing from Quick Performance Products in Iowa.
Moser 31 splines, detroit truetrac, alum 3rd member.
Great work, and cost effective--Brayden Sells on ebay.
Brakes:
C5 Zo6 Brakes in the making from kore3.
325mm fronts, 305 or 330 rears--not sure yet.
Electrical:
Getting harness from PCI Conversion.
Exhaust:
Evaluating whether I should use the stock manifolds, or buy Stainlessworks Headers from Speedtech.
Looking for a smooth/clean sounding 3" muffler (not too loud--any suggestions?).
Gas tank:
Rick's SS Tank.
Gauges:
Undecided---I like Dakota digital.
Currently my Front clip and hood are in my front porch (I needed room!), and I am in the middle of putting the rear suspension in. Everything has been going rather well, and I was able to fit the 6L90e in with out cutting the tunnel apart (Thanks to Champ Pans and the speedtech sub frame).
Hope to have it running mid summer! Thanks for looking!
https://static1.pt-content.com/images/pt/2011/04/IMG_1622-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG_1619-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG_1616-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG_1614-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG_1613-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG_1610-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG_1606-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG_1604-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG_1603-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG_1598-1.jpg
spencerbutts
04-18-2011, 06:37 PM
Looking great Bobby! You've made big progress since I came to see the car a few weeks ago--glad to hear that the tranny fit without having to cut up the tunnel!
Bobs 67Camaro
04-18-2011, 06:41 PM
Sure fooled me! May still have to do minor changes, but not bad. Now on to brakes, elec, driveshaft, intake, etc.....
68400BIRD
04-18-2011, 06:50 PM
Looks like some very nice upgrades to what was already a very solid platform.
Motown 454
04-18-2011, 06:58 PM
Nice project!
Bobs 67Camaro
04-18-2011, 06:59 PM
Thanks, I appreciate it.
It has been nice working on a car originally from Cali! Unlike every other project I have done, I have not had to torch off one bolt!
1red68
04-18-2011, 07:12 PM
It looks great! nice job!
are you going to make it to Car Craft??? if you are it would be nice to check it out.
johnny68
04-18-2011, 07:29 PM
hey Bobby looks great great suspension choice speed tech is great stuff its identical to my rear end
john
Bobs 67Camaro
04-19-2011, 03:06 AM
Yes, completion prior to the Car Craft Summer Nats is my Goal (if not, sooner). I may have a trip out to Dynotuneusa in Watertown, SD for some tuning with Andy.....hopefully not the weekend before CC!
monteboy84
04-19-2011, 04:53 AM
Looking great! Will the Twistmachine shifter work with a stock computer or what will you be running for a trans controller?
-matt
Bobs 67Camaro
04-19-2011, 05:35 AM
Matt,
The Twist Machine Paddles will work with the stock 6L90e TCM (it's actually in the tranny housing). I do not need their Shift controller. I just have to integrate it into my harness (3 wires I believe).
Bobby
monteboy84
04-19-2011, 06:54 AM
Man, that makes for a pretty attractive setup then, can't wait to see this thing done!!
-matt
Bobs 67Camaro
04-19-2011, 09:01 AM
You're right about that. It kept me from going with a T56! The 6L90e came with my L92. Apparently they are difficult to come by (only the 2WD trucks had a 6L90e with a splined tail shaft). I'll look for you at CC!
Junior13
04-28-2011, 12:45 AM
And I thought I was the only 67 owner with a set of those centerline rims!!! Good luck with the rebuild.
Bobs 67Camaro
04-28-2011, 05:03 AM
Nice, I still like them (I've had them for awhile). Unfortunately, they no longer make them in 2 pcs; therefore you can't buy them in anything less then a 20" rim. I am trying to buy a pair of 18" for the front (I currently have 17"s in the front, and 18" in the rear). I could use some extra brake clearance....wanna sell yours?
Junior13
04-28-2011, 02:18 PM
Yeah I like mine too. They stand out from the norm on these cars. I have a set of 18's in the front and 20's in the rear. Looks great, with a great stance. Why not move your rear 18's up front and buy a new set of 20's for the rear. I have a bent 18 that i searched everywhere to replace but you just cant find them. I found a guy here in NY that will repair it for me. Good luck.
Bobs 67Camaro
04-28-2011, 03:57 PM
I sure would if I could! My rears are 18 x 10" with 4.75" BS.....so they would never fit.
I suppose I will keep looking.
pollusky
04-28-2011, 08:03 PM
Great build is looking awesome.
killer67
04-28-2011, 09:33 PM
Love the build
Bobs 67Camaro
04-29-2011, 08:19 AM
Zo6 Brakes are going on this weekend! I will post picks soon.
jfreakofkorn
04-29-2011, 08:37 AM
I love it when the old meets the new. they were great cars in their time but needs some help ever so often with upgrades. I cant wait to see this at when its done =)
Bobs 67Camaro
02-28-2012, 06:40 PM
Took awhile, but I have been busy working in the garage. 90% of the car was completed in October/November. I was able to put a few hundred miles on before winter arrived!
The brakes for Tobin @ Kore 3 were perfect. Well packaged, thorough BOM, and great help on the phone!
https://static1.pt-content.com/images/pt/2012/02/IMG_1649-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_1648-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_1647-1.jpg
Perfect back plates! They were a shame to cover up!
https://static1.pt-content.com/images/pt/2012/02/IMG_1644-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_1653-1.jpg
New pan from car kraft:
https://static1.pt-content.com/images/pt/2012/02/IMG_1556-1.jpg
New 9" from Quick Performance in Iowa! Great value, quality, and service (thanks Brydon)
https://static1.pt-content.com/images/pt/2012/02/IMG_1574-1.jpg
I did have to re-machine the pinion support--not all flanges have the same pattern (speedtech assumed a strange 3rd member, I had a Yukon gear)
https://static1.pt-content.com/images/pt/2012/02/IMG_1578-1.jpg
I made custom Motor mount plates out of 1/2" alum plate:
https://static1.pt-content.com/images/pt/2012/02/IMG_1564-1.jpg
Installed a SS tank by Rick's:
https://static1.pt-content.com/images/pt/2012/02/IMG_16461-1.jpg
Pulled the TCM, and had the shift points quickened by Jim Miller at Zero Gravity Perf in Phx, AZ (Jim was a calibration engr @ GM for 25 yrs).
https://static1.pt-content.com/images/pt/2012/02/IMG_1637-1.jpg
Bobs 67Camaro
02-28-2012, 07:06 PM
I then went to Texas Speed and Perf:
I ordered a DOD and VVT delete kit with the largest cam I could fit without cutting the pistons:
(jesse, my friend wearing the "Man Thong Racing t-shirt", is an LS Pro)
https://static1.pt-content.com/images/pt/2012/02/IMG_1669-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_1667-1.jpg
I was told the motor had 1700 miles on it......seems like a lot of carbon for 1700 miles! (maybe 17k or 27K?)
https://static1.pt-content.com/images/pt/2012/02/IMG_1665-1.jpg
All Clean:
https://static1.pt-content.com/images/pt/2012/02/IMG_1677-1.jpg
Valve Springs:
https://static1.pt-content.com/images/pt/2012/02/IMG_1675-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_1664-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_1663-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_1661-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_1679-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_1660-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_1683-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_1658-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_1657-1.jpg
Ended up buying a used LS3 intake....and an F-body Acc system:
https://static1.pt-content.com/images/pt/2012/02/IMG_1686-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_1699-1.jpg
I could not help it, I had to get the headers!
https://static1.pt-content.com/images/pt/2012/02/IMG_1700-1.jpg
4th Gen Booster, right hand drive S10 Master cylinder (from Tobin). and the brake system was good to go!
https://static1.pt-content.com/images/pt/2012/02/IMG_1695-1.jpg
Protorque Converter--10" with a 2800 stall (through Twistmachine---should be fun with the Paddles:
https://static1.pt-content.com/images/pt/2012/02/IMG_1697-1.jpg
My helper (helper actually preferred playing "Angry Birds" over wrenching):
https://static1.pt-content.com/images/pt/2012/02/IMG_1705-1.jpg
Paddles from Twistmachine! Thanks Steve (he was very patient, helpful, and great to work with)
https://static1.pt-content.com/images/pt/2012/02/IMG_1702-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_1703-1.jpg
Gauges from New Vintage---very cool!
https://static1.pt-content.com/images/pt/2012/02/IMG_1704-1.jpg
Bobs 67Camaro
02-28-2012, 07:08 PM
With the help of 4 friends, the front Clip was back on!:
https://static1.pt-content.com/images/pt/2012/02/IMG_1706-1.jpg
Little too low for tire clearance! (had to get longer front springs from Roger @ speedtech--needed 10" instead of 8"--I also went to the 450# springs)
https://static1.pt-content.com/images/pt/2012/02/IMG_1708-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_1711-1.jpg
Tuning @ Jesse's shop (can you tell it was hot?)
https://static1.pt-content.com/images/pt/2012/02/IMG_1715-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_1722-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_1717-1.jpg
Off to get exhaust:
https://static1.pt-content.com/images/pt/2012/02/IMG_1725-1.jpg
Magnaflow 3" SS system did not fit, so I had Taylor Star Automotive do a custom 2.5" system. They did a wonderful job!
https://static1.pt-content.com/images/pt/2012/02/IMG_1721-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_1716-1.jpg
After tuning we found that the 90 degree ellbow I purchased from Steet and Perf could not be used, so I had a custom one built.
Thanks to Gino, Andy Wicks (Dynotuneusa), Jesse, Justin, and 15 gallons of gas, we were able to get the car running great!
68400BIRD
02-28-2012, 08:35 PM
Looks great. That is quite the list of upgrades you just installed in the car. I bet you can't wait for spring. I bought a set of the 69 vintage guages I really like how they look.
CruizinKev
02-28-2012, 10:01 PM
looks great!!! :twothumbs
Bobs 67Camaro
02-29-2012, 10:38 AM
I have some wiring, gauge calibration, and sound insulation ahead of me as well!
Hope to have everything ready come spring time.
