View Full Version : Carbureted Remote mount turbo?
thirdstreettito
04-12-2011, 10:53 AM
Anyone know of any carbureted vehicles running remote mount turbo's? Or a remote mount turbo? Thanks, Bradley
sam 74
04-12-2011, 02:46 PM
a guy i know dynoed a 327 small block with an STS kit on it and it made 450 lb ft of torque by 3000 rpm but it blew up shortly after, it was just a tester to see what would happen, the motor was pretty much stock internals.
thirdstreettito
04-12-2011, 08:18 PM
Thanks, yeah 450 on stock stuff is'nt exactly smart...
Anyone else have input?
shmoov69
04-13-2011, 08:09 PM
Worked fine for me!!
Don't know about a remote kit thru a carb, but it should work just fine. It would (I'm relatively sure!) have some considerable lag tho. Unless you got a programmable ignition box that you can keep timing a bit longer before yanking it out. But that is just my opinion.
thirdstreettito
04-16-2011, 03:21 AM
Anyone?
NJSPEEDER
04-16-2011, 10:23 AM
It wouldn't work any differently than remote mounting on an EFI engine. All the same principles still apply, need boost referenced fuel pressure and a pump that can handle it and a carb that can handle blow through.
-Tim
opnwide
04-18-2011, 10:33 AM
Agreed. I was seriously considering a remote mount setup myself. My issue was with the oil pumps to return oil back to the engine. I just didn't think they were reliable enough. Heck, my A1000 fuel pump makes me nervous, too. I hope it doesn't crap out when I'm pushing 15lbs of boost. I just want to keep things as simple as I can.
shmoov69
04-18-2011, 07:48 PM
The A1000 will be fine... Mine has been going for 8 years now.
I hope that didn't just screw me by saying that!! LOL!
opnwide
04-23-2011, 05:41 AM
Good to now about that A1000. A decade ago when I had my corvette procharged, I used a holley mech pump, boost referenced. That was the norm then, but the mechanical connections just seem more reliable than electronics. I've been stuck on the side of the road due to a bad electric fan connection within months after I installed it. I've had Ford ignition modules strand me. And yes, even the ignition on a LT1 firebird. The only mechanical breakdowns I've had are when I blow something up.
kmcanally
04-23-2011, 12:20 PM
Here is a remote tt setup in the ultimate sleeper not carbed like you asked for though http://www.hotrod.com/featuredvehicles/hrdp_0711_1963_pontiac_tempest_lemans/lemans_cont.html
thirdstreettito
04-23-2011, 06:45 PM
Thanks, that thing is saweet!
66larkgs
04-24-2011, 07:34 PM
I am new to this site but i run a custom rear mounted turbo setup with a blow thru setup. igarret t67 turbo .81 exhaust housing i also run a csu holley 750cfm 4150hp blow thru carb w/ ev carb hat. i run a a1000 fuel pump with a areomotive boost reference regulator, tial 50mm wastegate and bov, exa-werx oil pump .fast wideband o2 sensors to moniter and adjust the carb. i am getting ready for paint but heres a link
http://www.youtube.com/watch?v=dJCp9TsGe4E&feature=mfu_in_order&list=UL
http://www.youtube.com/watch?v=AviZHGBNj40&feature=autoplay&list=ULL-nTK8BYepY&index=1&playnext=1
I need to update my pictures but here you go http://s917.photobucket.com/albums/ad19/66larkgs/
shmoov69
04-24-2011, 08:04 PM
That truck is SWEET man!!!
thirdstreettito
04-24-2011, 10:02 PM
That lark is awesome! Thanks for the info!
MonzaRacer
05-01-2011, 01:47 AM
Yeah go over the theturboforums.com and look up Brent Davis, send him a functional dp holley and he can set you up with a blow through ready for boost, if you like doing your own work search for "the crutch" setup. Which basically is a small air pump controlled by rpm switch to activate the boost reference power valve.or look for hangar 18 mods also. hangar18.com
neat part on remote is it doesnt need an intercooler!
1970 TT Rustang
05-01-2011, 10:04 AM
Here is my setup its a 427 bill mitchell with accel dfi and mass flow tb iam intercooled. I dont know much about the blow thru setup
46489
46490
46491
thirdstreettito
05-04-2011, 07:18 AM
Hot damn. That thing is the bomb!
1970 TT Rustang
05-13-2011, 03:07 PM
THanks bro its a work in progress
