View Full Version : Aftermarket Harness - Oil Level Sensor - Oil Pan
67CamNKC
04-05-2011, 08:10 AM
Those of you running aftermarket harneses, are you running/using an OEM oil level sensor in the oil pan? I am looking at the cast Holley and MAST oil pans for my camaro. The MAST pan has a provision for the oil sensor and Holley pan doesn't. I also noticed that the Holley pan has a bell housing bolt hole cast in.
Any preference on either pan?
NBM-WU8
04-05-2011, 10:14 AM
In for more information.
It sounds like Holley is starting shipment on these pans this week. We don't specifically need the bellhousing bolt hole since we are going to use a 200-4R. This is the direction we are leaning in as of right now for our '88 Monte SS swap.
