View Full Version : SPC upper control arms for -66 Chevelle
osdmike
03-31-2011, 03:58 AM
Hi! I need info what length the adjuster sleeves are,front and rear,(see pic.) for -66 Chevelle. SPC arms.
Iīm not sure I got the right length.
Front is 6",rear is 5"
Part# 94324 Right,94325 Left
We had the car at the alignment shop.
When setting the caster angle +5*, it was impossible to set the the desirable camber at -1,25*.
Camber stayed on the + side.
If the sleeves were shorter, it would be easier to set the correct camber.
Lower control arms are CPP and the measure is consistent with the original to what I have heard.
Any suggestions?
ROBS6T8
04-02-2011, 06:53 AM
Have you called SPC? Great customer service for me. 1-800-525-6505 Sorry I don't have a Chevelle, but your part numbers are correct according to their website.
jocko124
04-02-2011, 06:56 AM
I have these arms on my 66 Cutlass. If I remember right, both the front & rear sleeves are the same length--6". If you're interested drop me a PM and I'll measure them when I get home tonight.
osdmike
04-02-2011, 11:25 AM
Problem solved, I think.....
Sleeves ARE the right length. 5" rear,6" front.
Couldnīt use the shims, with the 20* midsize plate,though.
The shims moved the upper ball joint outwards.
Thats why it was impossible to get negative camber.
We will take the car to the alignment shop and check again.
Thanks.Mike
ROBS6T8
04-02-2011, 12:49 PM
Good deal.
wmhjr
04-03-2011, 07:40 AM
I just measured mine. The adjuster arms (barrels) are exactly the same front and rear. These are the hex, billet adjustable uppers from Marcus.
osdmike
04-03-2011, 07:59 AM
Are they 5" or 6" long?
Since the GTO is also A-body,
do Your control arms have the same part number?
Part# 94324 Right,
94325 Left
osdmike
04-04-2011, 12:31 AM
Maybe the 20* plate has something to do with the different hex sleeve length?
Anyway,...problem solved!
Got the car back from alignment shop.
458214582245823458244582545826
