View Full Version : 1st Gen Suspension help
GO67SS
06-14-2005, 01:37 PM
Info: I have a 67 Camaro with Fatman Fab. Arms, 12pt QA1 (coil-overs),DSE 1/2" drop solid body mounts. My car is too low on the passenger side (tire rubs in the fender well when I drive over the smallest of bumps at any speed) and just about right on the drivers side. I have the coil-overs adjusted to the same height. I measured the frame height from the floor to the frame and it is the same. Any suggestions?
[/IMG][/IMG]
68protouring454
06-14-2005, 03:59 PM
roll the fender lip, so it is more round than square, also could be your subframe out of aligment, square the wheel base up
jake
GO67SS
06-14-2005, 05:00 PM
It is not rubbing on the fender lip just the fender well as the shocks compress. But thanks for your suggestions.
baz67
06-14-2005, 05:20 PM
It looks like you dropped it too much. Raise the spring on the coilovers. What is the rim size including the BS.
GO67SS
06-14-2005, 06:29 PM
The rims are 17x8 frt, 17x9.5 rr. How do I lift it back up. I have the coil-overs about 1" from the top. Has anyone used QA1 Coil-overs??? and adjusted them properly? Thank-you for your comments
GO67SS
06-24-2005, 01:26 PM
I removed the 1/2 drop DSE body mounts with rubber mounts and adjusted the coil overs to the maximum height. WHAT A DIFFERENCE in ride quality. The rubber mounts ride so much better.
mdprovee
06-24-2005, 01:33 PM
Glad you were able to fix your "problem" with rubbing. Car looks good Brihan.
Mike
baz67
06-24-2005, 02:49 PM
It may ride better, but it will handle worse due to the increase in body flex. Get the stock height solid body mounts.
