    Results 1 to 2 of 2
      Feb 2011
      Alabama
      72 camaro wilwood question
      Does anyone know if Wilwood recently changed the thickness of there hubs on the second gen setup? I went with a new set of wheels and they are rubbing the fender. I was going to change to a narrowed control arm but I just read that Wilwood may offer a hub that is not as thick as what I have. Any info on this would be much appreciated! It would be nice to order new hubs instead of control arms! Thanks
      Sep 2009
      Issaquah, Wa
      I don't think Wilwood makes a hub that will bring the wheel in much, so it depends on how far you need to go. I know my Wilwood kit pushed the wheel out about 1/4" further than stock and I also had a clearance problem with the bearing dust cap. They sent me a shorter dust cap to make it work without a spacer, but they couldn't do anything about the 1/4" that the wheel was pushed out.
