    Results 1 to 20 of 22
      Castro Valley, CA
      14" Baer All Around. Will Manual booster work?
      I plan on running 14" Baer 6 piston front and rear. My engine does not have enough vaccuum to run a power booster so I was going to use just my manual Wilwood master cylinder.
      Question is... Is manual OK for these brakes or will my leg be cramping after 10 mins of driving?
      Wanted manual to keep a clean firewall but will consider forking over the 700 for a hydroboost if Im going to need it.
      John S.
      68 "Bloodline" Camaro in assembly...
      Speedtech Sub, Alston G-Billet/Fab 9 rear, Ridetech coil overs, Moser axles, Fesler 19's, Lots of Anvil parts,Twin tubo LS3/T56, Carbon fiber manifold, and the list goes on and on..........
      East, Tennessee
      Subscribed!
      1986 Buick T-Type
      RideTech, DSE, BAER Brakes, Forgeline Wheels, LED lighting, More!
      * Get your Top of the line GPS Theft recovery devices Here!
      www.GNSperformance.com
      Apr 2004
      OKC, OK
      It will but will not provide seatbelt restraining stops without standing on the brakes Should be a 7/8 bore if memroy serves. If your looking to buy a set soon, I would get them on order this week. Baer is raising their prices 4/1 $300-$400 more on a front and rear set
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Sep 2001
      Accord, NY
      What's the area of the bear pistons? I used a 7/8" bore MC with a C4 setup which has small pistons and it stopped well in manual mode.
      69 Camaro convertible, 410, M22, 8-pt cage therapy program. SOLD.
      68 camaro - SOLD
      67 Bel Air - New street project with perfect floors, frame and trunk!
      Castro Valley, CA
      im not sure of area. i think wilwoods are smaller should i get those instead?
      John S.
      Dec 2009
      Quote Originally Posted by MuscleRodz View Post
      According to Baer, 15/16 master is ideal. I'm going manual. BTW, Wilwood dual master does not come in that size so I'm going to try 1" first....and stand on it!
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Castro Valley, CA
      I bought a manual wilwood master this weekend at goodguys but I dont know what size it is.
      John S.
      Dec 2009
      Size matters. Wilwood dual master says the size on the side. Take a look and report back...
      Ron in SoCal
      Dec 2009
      El Dorado Hills
      Quote Originally Posted by Ron.in.SoCal View Post
      Ron, might be a good idea to talk to some peep's that have a tried and true set up. I'd hate to see you spend your money twice.
      Gaetano Cosentino
      Dont Drive Faster Than Your Angels Can Fly
      Castro Valley, CA
      It is a 7/8.
      John S.
      Scottsdale, AZ
      I'm running stop tech str's 6 piston up front and 4 piston in rear manual with .700 Tilton MC.
      69 SS/350 Camaro
      AME Front & Rear LT Build
      69 SS/396 Camaro
      LT4 Build
      71 K5
      Castro Valley, CA
      Well I ordered my brakes today. Baer 6P 14" front and rear. Hopefully they wont be too hard to stop with a Wilwood 7/8 manual booster.
      John S.
      Dec 2009
      Quote Originally Posted by Gitter Dun View Post
      Words of wisdom Gae. I tried some time ago to get some real world feedback but couldn't track anyone down - prob should of tried a little harder! I actually have a 7/8 that came w the car and bought a 1" after I got the brakes. Not sure which one will do better, but I'd love to hear from others. If not, I'll be the 6P tester...
      Ron in SoCal
      Scottsdale, AZ
      Check out this link. Lots of good info.
      http://www.stoptech.com/tech_info/te...e_papers.shtml
      69 SS/350 Camaro
      69 SS/396 Camaro
      LT4 Build
      71 K5
      Newbury Park, CA
      If I'm not mistaken, Bad Penny is running 6Ps on all four courners with a 1" manual master. Details here: http://www.camaroperformers.com/cama.../photo_07.html
      Mike K.
      67 Camaro RS
      Aluminum 509, Procharger D1-R
      CarCraft Feature
      Dec 2009
      ^ Great post Corey. Lemme go get my calculator...
      Ron in SoCal
      Dec 2009
      Quote Originally Posted by mike67cam View Post
      We need Steve to jump in here. D*ck @ BOS told me he went down to 15/16 IIRC...
      Ron in SoCal
      Jan 2009
      I thought Steve was still running the 1" but thinking of going down to the 7/8" again, but then again, I can't keep track of all of the changes that get made to Bad Penny.
      John, in my opinion, you'll be fine with the 1" master cylinder. I originally had a 7/8" Wilwood piece on my car and it was really easy to operate under normal driving situations. My leg never got tired. Recently I switched over to a Tilton setup with individual front and rear master cylinders that are both 7/8." I now have to stand on the pedal to get the brakes to lock up, but even so, under everyday driving conditions I really don't have to apply that much effort to get the car to slow down casually.
      Matt
      Charlotte, NC
      I have posted this before in other places so if you have read it before I am sorry. To cut the story way down...after lots of trial and error and some good recs, I am running a 7/10 Tilton in the front and 3/4 in the rear with a 6:1 pedal ratio. My Wilwood 6 piston front and 4 piston rear on 13 inch two piece rotors. That got my pressures at the caliper to 1200 psi and 950 psi rear with normal leg pressure of around 100 lbs. What completed my system was a switch to Carbotech AX6 pads all the way around for street driving and auto cross. Use Carbotech Xp10's front and AX6 in rear from track day with street rubber. The pads made a huge difference in my stopping ability. Use to have to stand on it with both legs with Wilwood BP10's, not any more. I am not sure of the piston area difference in a Baer set-up and my Wilwoods.
      If you are NOT running a dual master system the consensus has been 7/8 or 15/16 for manual applications with the Wilwood and Baer kits. Smaller the master, the less leg pressure, more brake pressure, more pedal travel.
      East, Tennessee
      Quote Originally Posted by Payton King View Post
      Good info, Thanks Payton!
      I just went with a BAER system myself....
      1986 Buick T-Type
