    Results 1 to 14 of 14
      Delaware, OH
      Painting rusty rotors
      The night before I was to leave on the Power Tour I washed my car for the first time since installing my 4-wheel discs. Much to my dismay the rotors were IMMEDIATELY covered in surface rust. I ordered the zinc plated rotors but obviously that's not what I received.
      Anyway if I pull the rotors and clean off the rust, can I just spray them with high temp rattle-can paint? Will that work well to keep the rust off the non-contact areas? I assume the pads will easily wear the paint off the contact areas.
      Dan
      North Jersey
      Quote Originally Posted by dhardison
      Dan
      I used engine-enamel on the "hats" of the rotors, because you can see them behind my wheels. You could remove the rust with some 120-grit sandpaper, then spray the whole thing down with brake cleaner to clean it off, then paint whatever color you like. Another paint option is Krylon's caliper paint. When that dries, it looks almost like powdercoating, and is very hard. I did my cast-iron calipers with that, and they look great so far.
      Steve Ragusa - North Jersey
      2006 Infiniti G35x
      Nov 2000
      O-town
      Dan, I had my rotors Zinc washed, I know the actual rotor surface will wear the zinc off, but the rest shouldn't rust, I send you a pic when I get home to show you what they look like, Steve
      Delaware, OH
      Thanks to BOTH Steves!
      Steve68, where did you get them zinc washed? Can that be done even though they've already been broken in?
      Dan
      Sep 2004
      I had mine Zinc Washed also. The rears were a used LS1 setup from a late model camaro, and the fronts were new Touring Classics rotors. The plating shop cleaned up the used rears for me and they came out great! I paid about $70 to have all four rotors done.
      Sterling Heights, MI
      Don't leave the paint on the pad contact surface. This will compromise the stopping ability. Either mask off the contact surface, or do a light turn of the contact surface after the paint has dried.
      Using the car in front of you to stop would be a bad thing...
      Ancient Chinese Proverb: "Injection is nice, but I'd rather be blown!"
      1964 Studebaker Daytona - Laguna Blue, Original 4-Spd. Car, Power Steering, Disc Brakes, Bucket Seats, Tinted Glass, Climatizer Ventilation System, AM Radio (136,989 Miles)
      1992 Suzuki Swift GA (SCCA H Production Race Car) - 1.3L SOHC, 5-Spd., Limited Slip, 4:10 Final Drive
      Nov 2000
      O-town
      Yes, they can do the rotors, Joe paid a hell of alot less than I did, I might have to shop around for the rears,
      Dan I send the pics tomorrow, to busy today, Steve
      Aug 2003
      Orlando, FL
      We jet hot coat them.
      Delaware, OH
      Frank, How long does it take for the pads to wear the JetHot coating off and how badly does that affect braking performance until it does wear off?
      Dan
      Delaware, OH
      Also Frank, does the JetHot coating drastically affect rotor runout? I'm running a rotor had with separate hub.
      Thanks again,
      Dan
      Nov 2000
      O-town
      Franks got a good idea, I always liked the zinc wash,
      Delaware, OH
      I contacted JetHot and they say they won't coat brake rotors. Frank, do you use a different company?
      Dan
      Indianapolis IN
      FWIW, I've hit them with a wire brush mounted in a drill motor and then once the crusty rust is removed, shoot some GRILLE paint (bar-b-que grille) paint on them. Its designed to take the high temps and does just fine and its UBER CHEAP..
      Sure, its not gonna look as sharp as zinc washing, but depends on your goals.
      Nov 2001
      Sacramento Ca
      Dan, im sure they arent talking about useing jet hot on the rotor surface that the pad touches. just the hats.
      any coating on the pad mateing surface will eventually rub off and you'll get some kinda rust if your car sits any amount of time. Zink coating may be the only alternative.
      Tony Langlois
      1966 Corvair Monza
