Results 1 to 16 of 16
03-07-2011 #1
HID's or high power halogen bulbs?
I have had enough of trying to make my Autoloc (plastic housing - Glass lens) tribars work. The standard halogen bulbs are not bright enough for night driving. When I placed the higher power halogen bulbs in the housing, it started to melt everything. I threw away all the 4 lights and got 4 new ones. ($19 ea) plus bulbs which were thrashed.
Now that spring and summer is coming, I don't want to be caught with crappy lights, which a performance car can easily overdrive.
I am torn. I like the classic look of the tribars, but am looking at the eBay HID kits. I'd lose the classic look with these, I think. I don't know much about them, though. Are they any good or just junk? such as these?
http://cgi.ebay.com/ebaymotors/H5006...item20b79a97fc
The other thing, that I was thinking of going with is a complete glass housing, which would not melt with the higher powered bulbs, something like these;
http://cgi.ebay.com/ebaymotors/5-3-4...item4ce72e9608
Any suggestions, much appreciated
03-08-2011 #2I love HIDs so I would never use anything else. No halogen bulb I have seen can match the lighting of an HID. Also, HIDs run at much lower temps so you won't have any heat issues.
03-08-2011 #3Biggest problem I can see is finding a HID kit that actually has the proper reflectors/lenses that will focus the light out past the first 20-30 ft of the car. Those don't come cheap and you really can't them in a $200 kit.
Check out this thread on the subject:
https://www.pro-touring.com/showthre...ogen-HID-FACTS!!
03-08-2011 #4Here are a few more options in some quality H4 bulbs, so you have something to fill the gap between 55w and 100w, which the 100w I think are a bit too much for street-driven.
http://www.rallylights.com/Hella_H4_Bulbs.aspx
The 100w H4 are 'almost' the same Lumens as what an HID lamp can produce. Now 100w are considered 'off-road' use only, and actually none of the HID retro-fit or re-based bulbs are DOT approved either.
If you need more light on the road, get rid of the tri-bar, since any obstruction in the reflector can reduce the amount of light on the road.
Also, the blue-tinted bulbs filter out about 10-15% of the light based on what color range. From 3200 to 4300 you lose about 10-15% of the light, if you get some 6000K bulbs you just filtered out about 20-30% of the light produced.
The HIDs also behave in the same way, the higher the color range (in degress Kelvin) the less light is actually put on the road, from 4300 to 6000, to 8000k, to 10,000k you lose 10-15% of output (in Lumens) in each step.
And just to beat a dead horse, on rainy roads, or recently paved roads, the blue color range bulbs are practically useless, the light is mostly absorbed and you will not see jack. HIDs since they emit more light, can manage losing a bit of efficiency when running the higher color ranges.
The Autopal brand makes a good quality replica of the Bosch/Hella H4 design, and many have metal reflector, and glass lens.
I prefer the quality optical lens, instead of the 'diamond' style myself, as the light has a uniform pattern.
http://cgi.ebay.com/ebaymotors/5-3-4...Q5fAccessories
Here is a link to some Hella lamps:
http://www.rallylights.com/Hella_5.7...Headlamps.aspx
Here is a link to a source that sells the Bosch lamps:
http://www.danielsternlighting.com/p.../products.html
BTW, I do not use the H1 high-beam lamps, I have had problems with moisture somehow wicking into the lamps, even after silicone in the boot and/or plug wires, etc, I tried everything, although I live in a high humidity area, but with all H4 bulbs, you can swap them around if one blows out.
My H4 have not had any problems with moisture condensation, I have been using them for 20+ yrs on all of my cars.
Here is some food-for-though about HID lights:
http://www.danielsternlighting.com/t...dvantages.htmlDave
03-08-2011 #5
- Join Date
- Jun 2010
- Location
- washington state
- Posts
- 58
I seen the 129 kit on ebay and also wondered how good the light quality was. anyone use them? or any from ebay?
03-08-2011 #6Thanks guys, some great information there. The last thing, that I want to do, is have a cheapo set of HID's that are blinding motorists around me.
03-08-2011 #7
