    Results 1 to 9 of 9
      Dec 2009
      1970 Torino Gt build
      Recently started tearing into my new project. Its a #'s matching 70 Gt 351 cleveland w/4 spd toploader & hurst shifter, black on black. Motor is currently at machine shop, its getting a 408 stroker kit, aussie 3v heads and matched intake. You get the idea.
      Anyhow with HP being in the 600 range i am wanting to build a full frame for the car. I have searched the net high and low for mustang 2 front ends, custom chassis, torino chassis etc, and cant so much as find a schematic on the factor unibody to use as a starting point. Wanting to go 4 link in the rear and a mustang 2 type setup up front with a power rack. Any ideas where to find some info on this? Also i have found all the replacement sheet metal that i need except wheel houses, any ideas here? I will be with a 10" wheel in the rear so im thinking mini tub. Thanks in advance for any help! I can throw up a project thread if anyone is interested. :lateral:
      Apr 2010
      Pittsburgh, PA
      looking forward to the build as this is my favorite ford ever!
      is it a fastback :-D
      it always looked soo damn similar to the 68-72 GM abodies and was always curious if an A-body frame would work with a lil fabbing
      front suspension should be the same componets as any ford mustang/maverick/cougar.
      Coil-over Strut mount
      http://www.rrs-online.com.au/frontcoilovers.php
      Rack & Pinion Steering
      http://www.rrs-online.com.au/rack&pinionproducts.php
      not sure about the rear suspension but try total cost, or rss 3link...havent really research 4 links for the ford cars?
      if you find out the rear is the same as a stang or cougar then there should be a good bit of bolt on torque arm and 4 link kits
      72 buick skylark
      twin-turbo fuel injected buick 350..perhaps stroked to 370 in the works!
      Nov 2007
      Dayton, Ohio
      Check out AM Morrison's MaxG chassis.
      http://artmorrison.com/maxg.php
      Roger
      69 Mustang coupe, under construction
      2011 Mustang - DD
      https://www.pro-touring.com/threads/...ang-SuperCoupe
      Freedom Of Speed!
      Dec 2009
      here are some pics from before i gutted the car
      Dec 2009
      Quote Originally Posted by Nothingface5384 View Post
      yes its a fastback. I plan on doing all the fab work myself. time to put that engineering degree to use lol
      Dec 2009
      Anyone have a good line on a hood?
      Sep 2010
      Otsego, MN
      Very cool! Looks like it will be quite the project!
      "Project Scarelane" - 1967 Ford Fairlane 500XL Pro-Tour
      Dec 2009
      Quote Originally Posted by Scarelane View Post
      You said it!!! Kind of like a bad christmas, everytime you unwrap something you find a new hole!!! lol
      Dec 2009
      Im gonna have some stock parts to get rid of as i go along. So far.....
      351 c Stock distributor - Can get numbers if you need them
      Bladder tank for Hideaway headlights
      Actuator for hide away headlights
      origional 2v intake
      origional 2bbl carb
      2v air cleaner w/o snorkel
      valve cover
      2v heads and manifolds
      im sure the list will continue to grow as i get deeper into it
      What i need
      R & L Front fenders
      Hood
      front bumper
      Front and rear stone guards
      Pass side door
      4 spd toploader Z bar
