View Full Version : Beehive springs
442olds
06-09-2005, 05:04 AM
The comp cams tech guy is suggesting that I switch from a 340in\lb dual spring with damper to a single beehive spring which summit lists as a 130 in/lb spring.
This is on a full hyd roller setup on a bbc using factory style bbc gen 6 lifters and retainers. Cam is an xe-294-hr comp cam.
Does this sound right. Comps website seems to be broken at the moment so I can't read up on the beehive springs and how they compare.
rocketman
06-09-2005, 05:54 AM
i have used the on a lot lt-1 and ls-1 engines,they work great and because theres less spring the engine will revs quicker.i like them for those appilcations never tried on anything else yet.
