    Results 1 to 6 of 6
      May 2009
      Morehead City, NC
      Power steering jerking back and forth violently
      What would cause a power steering box to jerk back and forth? I have a sbc with a stock type power steering pump. I also have hydro boost brakes. I'm pretty sure I have plumbed it correctly. I had just started a fresh engine and had the front wheels off the floor and was going to turn the steering wheel back and forth, and as soon as I touched the wheel, it jerked back and forth very violently. I've never seen or heard of this. Can anybody tell me what is wrong? thanks
      Pensacola, FL
      I had this exact same thing happen to me on my ford rack & pinion. I swore I had it plumbed right, but it was backwards. I switched the lines, all was fine. Scott
      Morehead City, NC
      Quote Originally Posted by surnufz View Post
      By the way, he surnuf had it plumbed backwards. He switched the hoses and all is good now.
      Jun 2001
      Orlando, FL
      Quote Originally Posted by Mike
      Correct plumbing will cure a lot of things, lol.
      ​John Parsons
      Central CA USA
      That happened to Matt on a DSE rack, it damaged the rack.
      Jan 2009
      Quote Originally Posted by David Pozzi View Post
      Yes, I've heard of different things happening, but in my particular case the wheel spun violently to the right and then bounced off the bump stop. We put it on a lift and when I spun the wheel quickly to the right it felt like the gears were slipping, because it felt "notchy." You could see that front wheels didn't turn in a smooth fluid motion with quick steering inputs.
      Moral of the story, make sure to check steering on and off a lift. We didn't realize the rack was broken for a couple of months afterward.
      Matt
