    Results 1 to 1 of 1
      Jan 2010
      Delaware
      solid body mount torque specs on 2nd gen bird?
      Have a set of the Competition Engineering aluminum body mount bushings I'm getting ready to install on my 73 trans am. Question is...does anyone know what to torque them to? I searched but not having a lot of luck. I have heard between 75-85 as factory spec with the original rubber/steel bushings, and someone mentioned torqueing higher than that with the aluminum ones.....
      1973 Trans Am 455 SR block, ported 6x-8 heads, solid cam, Victor intake, 830 CSU carb, aluminum rods, 77mm Garrett turbo and methanol injection. 1064hp at the flywheel@5500 rpm
