Results 1 to 2 of 2
02-22-2011 #1
New to Pro-Touring
- Join Date
- Jan 2010
- Location
- Long Island, NY
- Posts
- 13
Question about telescoping shaft and steering column???
I have a 78 firebird. I am changing out the old steering box this spring. I am going to put in a quick ratio and rebuild the rag joint with a polyurethane pad from NPD. My question is the other end of the steering system by the column. I have supplied a picture of what it looks like in my car. I have not taken it apart I just want to get all the parts I need before I disassemble.
I am going to buy a new telescoping shaft. How does the dd shaft connect to the steering column??? Is it just a old, large u joint. Should I just buy a new needle bearing joint from flaming river to replace the old one. Does anyone know the size. The rag joint is 30spline x 3/4, i know the telescoping shaft I am buying is a 3/4 (rag end) 1"dd (column end), what is the spline count on the column. is it 36?
I am also going to buy the quick ratio box from agr...have people had good experiences with this one???
and input towards this job is appreciated...thanks
