Results 1 to 3 of 3
02-14-2011 #1
- Join Date
- Sep 2010
- Location
- Redding
- Posts
- 7
Power steering pump for rack n pinion
I need to know if a standard OEM power steering pump will work with my newly installed rack and pinion steering. This is a 68 camaro. I will most likely replace the pump ( cosmetic reasons ) but want to make sure I get the correct pump. Also, I will replace the stock lines with steel braded lines. Does anyone know the proper size fittings for the rack? I believe the supply side is smaller than the return side. Is it AN or pipe threads? I got rack from TCI -not sure of the brand.
