    Results 1 to 20 of 38
      Aug 2010
      St Charles, IL
      70 Chevelle on 18" Wheels - Thougts?
      Hey all,
      Tried to do a poor-man's manual photoshop for my '70 Chevelle build. Car is completely apart now, so I "borrowed" a photo from Google of another Shadow Gray '70 Chevelle, printed it out with a picture of the Jarvis '68 Chevelle as close to scale as possible, and cut & pasted the wheel setup onto the '70 stocker photo.
      What do you think? I know the front wheel scale is a hair off (smaller than real life), but I think we have a winner - now if only I can find out from Team III if the wheels will clear my 14" Baer Pro-Plus brakes that are soon to arrive.
      Stock
      Jarvis' 68 with 18X11 305/35 & 18X9.5 275/35
      My proposal:
      I know the image quality is crappy, but I don't have photoshop or the skills to clip the wheels & alter the stance of the car digitally (any image experts care to take a stab at this one?).
      Think these will work? In reality, I was thinking that I'll probably step back to a 18X10 305/40 on the rear (18X11 in a stock wheel house might be pushing it & I like a little more sidewall on my tire...)
      Oct 2008
      Durham,NC
      It will work there are more then a few here running 305/35/18's in rear if you wanna be saf side roll the lips so they do not touch side walls.
      Jan 2010
      Delaware
      That will really give the car an aggressive look, not to mention improved handling, braking, etc. I like! Assuming you've got the BS figured out already?
      1973 Trans Am 455 SR block, ported 6x-8 heads, solid cam, Victor intake, 830 CSU carb, aluminum rods, 77mm Garrett turbo and methanol injection. 1064hp at the flywheel@5500 rpm
      Aug 2010
      St Charles, IL
      Although I'd love to go 18X11, I wonder if that would be too much width for the stock wheelhouse, even with the lips rolled (which will definitely happen - new quarters going on the car this month). So, I'll probably go 18X10 - seems like 5.75 or 6" of BS is what most folks are using on an 18X10. For the front, if I can't get 18X11 in the rear, I think I might have to step down to an 18X8 with 4.5" BS, just to make things look right (don't know how good it would look with 18X10 rear and 18X9.5 front; Team III doesn't make a 18X9 in the Classic V's).
      Now if I can just get a return phone call/email from Team III on the Baer Brakes clearance question, I can get closer to making a decision.
      Rob
      Feb 2003
      I'm running 18 X 8 in the front and 18 X 9.5 in the rear on mine. It has Hotchkis Suspension and Baer 4-Wheel Disk Brakes. I believe the front backspacing was 4.5" and the rear was 5.5". The wheel wells are stock with no modifications.
      Brian
      Jan 2002
      Italy
      You have a winner for sure, I love them wheels myself.
      18x11" should fit in the rear without problems if the 1970 have the same wheelwells, I have 13 1/2" of wheelhouse on my 1968 Chevelle
      Have Fun!
      André
      2009 Chrysler 300C Touring.
      3.0 liter V6 diesel, five speed auto, black with light grey leather.
      1968 Chevelle Coupe.
      355cid, Viper T56, Corvette C4 IRS (Dana 44) and Corvette C4 IFS with Porsche 6piston Brembo's.
      1980 Chevy Van (shortie G10).
      355cid, TH350, 8.5" 10bolt posi and Belltech spindles.
      2000 BMW 540i Wagon. (FOR SALE €7K)
      4.4 liter V8, six speed manual, lowered and with Bilstein B8's, silver with black leather.
      2001 Ford Focus Wagon.
      1.8 liter turbo diesel, and a whoppin 90HP.:bsjerk:
      1968 Benelli Motorella
      foldable 50c scooter to go in a car trunk.
      2x '90s Yamaha TZR 2stroke bikes.
      one 125cc one cylinder and one will be 350cc two cylinder.
      Aug 2010
      S. FL
      11" hoops costs considerably more than 10".
      That in itself was enough for me to choose 10's, as the extra cost just was not worth it.
      Greg
      1969 Camaro Vert RS SS
      Aug 2010
      St Charles, IL
      Well, today I went and picked up the car from media blasting and it looks like WIDER wheels are definitely feasible, as the inner wheel houses turned out to be swiss cheese, along with the 1" of trunk floorpan nearest the wheelhouses (will post pics of the cancer when I download the pics). So my thought is this: install the new stock inner wheel houses inward 1-1.5" of their stock location (over the top of the frame at this point) and then weld in a strip between the inner & outer wheelhouses to give me some extra room. I've got a good bodyman/welder who said it would be no sweat to do this, as the inner wheelhouses need replacement anyway. 18X11 rims should fit with minimal issues then, right? Any idea on backspacing? I've read that 6.5" will cause the inside of the wheel/tire to hit the frame, and 5.5" BS seems to be recommended for 10" wide wheels, so will 18X11 with 6.0" BS be best in the rear? Tires - is a 305/40 or 315/35 best for a lightly lowered chevelle PT car?
      As for the fronts, it looks like I should go 18X9.5, 5.5" BS with a 275/35 or 275/40 tire (I like a little more sidewall, but I realize it has to fit in with the size/sidewall ratio of the rear wheels, too.
      What do you all think?
      Rob
      Oct 2008
      Santa Fe Springs, CA
      Quote Originally Posted by RobLinke View Post
      Hey all,
      My proposal:
      RobLinke,
      The photochop looks awesome, but be careful about lowering too much. You can run into a lot of ground clearance problems for real-world driving.
      Brian,
      You Chevelle looks and sits great! It looks like a car you can drive anywhere in style.
      Hotchkis Sport Suspension
      Toll Free: 877-466-7655
      Sep 2010
      Otsego, MN
      I think it looks cool. As long as it's all measured and fitted properly, it will look good. I thought my builder was nuts when he said he wanted to put 18's on my Fairlane. But I was wrong. Looks awesome! Are you gonna do big brakes too? That makes a big difference. I have Wilwood 6-piston 13" on front and 4-piston 12" on the back.
      "Project Scarelane" - 1967 Ford Fairlane 500XL Pro-Tour
      Aug 2010
      St Charles, IL
      Well, I had a few conversations with Scott over at Team III wheels. Turns out the big 'ol 14" 6 piston Baer brakes I will be running on my ATS AFX spindles WON'T clear the ET Classic V wheels (brake caliper sticks out 0.95" from hub face and the Classic Vs only have 0.75-0.78" clearance). Looks like I either have to use a 1/4" billet spacer or go to a custom wheel where they can adjust the mounting face depth to fit these large calipers. My backup option is the NewGEN Five Hundred in 18X9 and 18X10/11 painted to look like the original SS wheels, complete with billet SS caps. My only concerns are the overall cost ($4K+ with tires) and the fact that no one has an example with which to compare. I'm having a hard time convincing myself that I want to be the first one to get these wheels in this configuration and that I'll be happy.
      Decisions, decisions...
      Dec 2007
      Lombard, IL
      couple helpful threads.
      https://www.pro-touring.com/showthre...lle&highlight=
      https://www.pro-touring.com/showthre...ons&highlight=
      Musclecarjohns 70 chevelle, it is just so right!!!
      18x9/18x10 with 275/35 & 305/35
      Dan
      1971 Chevelle Maliboo Convertible 496/4L80E
      1956 210 2 door Sedan 8-71 blown 468/T400
      Oct 2006
      Corona, CA
      Funny you should say that. We LITERALLY have a set of 18" NewGen 500's in the shop, right now, that we're about to send to paint. They are going to be finished charcoal grey/polished, but you'll get the idea. If you can hold on for about a week, we'll have something to show you in 18" painted similiarly to what you want! Call me to discuss if you like: 1-866-694-5940. Also, we set up John's car above, as well as many of the 68-72's here and on Chevelles.com with the Nitto 275 and 305 combination as we figured out the ideal backspace for this set up. As always, happy to help.
      Roswell, N.M.
      Genuine Boyds Vintage 5 can be built to clear the Big Baer Brakes. Also the wheel can be built in any 18" size and backspace. Also any color choice(s).
      18 x 7
      18 x 8
      18 x 9
      18 x 10
      18 x 11
      18 x 12
      18 x 13
      18 x 14
      18 x 15
      http://www.billetwheel.com/vintage5.html
      Roswell, N.M.
      Aug 2010
      St Charles, IL
      Well, needless to say, I would LOVE to see those 18" NewGen 500s when they come out of paint (as others would, too, I'll bet). I've talked with Justin @ Driverz Inc and even got a preliminary price for a complete set of 500s & tires shipped out to the Windy City area - the only thing that caused me to hesitate is the that no one has any photos of a Chevy with these wheels installed with a factory-type look (brushed spokes, charcoal gray windows & SS caps). Hopefully that will be solved soon!
      Perry - I haven't forgot about the Boyd's either. My other option is the Ultimate 5 with a brushed center & polished hoop.
      I guess my third option would be to buy both. I could always put a board over the extra set and use it for a chair after the divorce....
      Thanks for the ideas, guys. I suppose the idea of running a 1/4" spacer behind the Team III's (or the VWW V40/45s) isn't recommended if I plan to push the car once it's together?
      Roswell, N.M.
      Either myself or Justin can take care of you.
      Enfield, CT
      Quote Originally Posted by DriverzInc View Post
      Wonder whose those are! I'm looking forward to seeing pics too!
      -Colin
      and here's my proposal
      Sep 2010
      corona,ca.
      i talked with team III in the past and seemed to me the guy was very negative about my C5 conversion or any big brakes for that matter really turned me off from buying there wheels.im going with rushforths from jon@ drivers inc. such a nice guy answered what b.s and tire size would work best for my set up.to bad im not buying them this tax yr. where saving for a house,so ill have to wait till next yr. :(
