Results 1 to 5 of 5
Thread: performance wheel question
02-10-2011 #1
Banned
- Join Date
- Dec 2009
- Posts
- 256
Hello,
Just to keep it short and simple and less for you to read
... 68 Charger built at 3200lbs with 32lbs per wheel on all 4 verse a 3200lbs charger (same weight) with 19lbs per wheel on all 4.
In terms of handling will they be identical around the the track considering they both weigh the same or does one work out different because the actual wheels are lighter/heavier even though the overall weight is the same between the 2?
If there is a difference even though both weigh identically 3200lbs, how much lighter (or what weight) would the charger with 32lbs per wheel need to be to end up the same as the 3200lbs charger with 19lbs wheels?
Reason I ask is not because the 'minor' difference that it may receive could cost extra 5000 dollars but because the only wheel I found to like on the charger is the heavier wheel.
02-10-2011 #2I have done alot of back to back testing on the drag strip and saving that amount on the rotating mass would amount to about .15-.20 in a quarter mile. I don't see why some savings would not be realised under braking also (although I have done no testing of this but common sense.......well nevermind.) The decrease in rotating mass increases the acceleration and deceleration of the wheel, provided you can transmit that accel/decel in the form of traction. Now you add those tenths up......
Jeff "the Jet" Jordan
02-10-2011 #3
