View Full Version : 68 to 69 Rear quarter conversion?
327ci
02-09-2011, 11:18 AM
I have an all original really clean, nearly rust free Numbers matching 68 camaro 327/4speed convertible. I'm going to replace the trunk pan and rear quarters. Is it possible to use 69 quarters? Being a numbers matching car would that plus a mini tub devalue it at all? This is my first muscle car that hasn't been hacked up.
Sean
Bow Tie 67
02-09-2011, 11:28 AM
I think it will make it harder to sell.
ErikLS2
02-09-2011, 01:05 PM
I wouldn't think it would be desirable to most, certainly not to me personally
Ron.in.SoCal
02-09-2011, 01:43 PM
I wouldn't do it. It's either a 68 or a 69. Frankenstein's (no offense intended to you or your build) don't typically retain much value or market appeal.
My .02
Rod
02-09-2011, 02:03 PM
Do not do it!!!
it will not (repeat Never) sell!
69 quarters are wider and then then you have to replace the tail panel inner trunk structure gas tank, just as a start
if you want a 69 then buy one and sell the 68 to another member who would want a 68
327ci
02-09-2011, 03:12 PM
68 quarters it is. What about the mini tub is that bad? What about dropping in an ls3/T56? Is that viewed as a negitive? Current engine is numbers matching 327/4speed 30 over with a little cam but still has factory carb and intake. obviously I would hang on to the original powertrain.
Rod
02-09-2011, 03:50 PM
Mini tub is fine many owners would not mind such a thing and its not a noticable (or damaging) change
777jetdr
02-09-2011, 05:28 PM
If you plan on keeping the car, build the car that you want. If you don't, don't change anything that can't be undone without much effort.Sit down, research & plan your build the best that you can. You will waste less money that way. Definately leave the 68 quarters.
