View Full Version : Using Fiberglass next to exhuast pipes
The Stickman
02-08-2011, 02:25 PM
Ok I am planning one doing a rear diffuser for my wagon. The idea I have is to use fences on each side of the exhaust pipes. My question is wether that is ok. Can fiberglass take the heat? I don't want the darn thing catching fire. I could adhere some aluminum to the side next to the pipes if I had to and that might reflect some heat. I would love to hear what everone has to say.
elitecustombody
02-08-2011, 07:09 PM
As long as the exhaust tip/tail pipe is protruding an inch past diffuser and has about an inch of clearence,it should hold up just fine,
tstarx
02-08-2011, 08:32 PM
fiberglass can take alot of heat it's the resin that burns. You can get a high temp epoxy resin your good to go or get regular polyester with a additive to raise it's heat range.
fbody_mike
02-09-2011, 07:59 AM
What they said ^. Wasn't there a car in the 24 heurs de LeMans a couple years ago that caught fire because the resin was not cured on a recent repair job.
I have a turbo motorcycle that has headers within about 1 inch to the fiberglass body work and never had a problem.
