View Full Version : Hood weights
The Stickman
02-08-2011, 01:50 PM
Ok I am curious as to normal weights for Hoods wether they are stock, Fiberglass, or carbon fiber. The reason I ask is I just weighed my stock aluminum hood. It alone weighs 26 lbs with the hinges and springs weighing another 4 lbs. Now I have not yet weighed the stock steel hood but I know it's heavy. But I am curious to see what everyone else has.
Bryce
02-08-2011, 03:34 PM
1965 falcon:
steel = 39lbs
fiberglass ~20
The WidowMaker
02-08-2011, 06:02 PM
stock 70 chevelle ~80lbs. maybe someone else has the rest.
80 MONZTA
02-08-2011, 07:28 PM
1980 Chevy Monza (4 headlight style) stock steel with hinges: 40lbs.
DarkoNova
02-09-2011, 10:37 AM
Going off memory, but stock 69 Nova hood was around 50 lbs. Don't remember what my fiberglass hood weighed.
sik68
02-09-2011, 12:01 PM
From my 1968 Camaro
Reproduction steel cowl hood: 50lbs
Fiberglass bolt on hood: 26lbs
chr2002ca
02-09-2011, 01:42 PM
I was actually curious about this also so thanks for starting this thread. I'd also be interested to know the difference in weight between an original/NOS hood and a repop hood for a first gen Camaro. I've often wondered if the weight savings that people quote for fiberglass/carbon fiber/aluminum hoods is versus an original steel hood or a repop steel hood.
nekkidhillbilly
02-13-2011, 12:38 PM
66 skylark was about 67 lbs for the steel
NOT A TA
02-13-2011, 01:50 PM
Original 70-76 Trans Am hood 65 lbs without latch post or hinges. Just weighed it to add the info to this thread.
The Stickman
03-02-2011, 09:25 PM
Ok I weighed my hood and hinges. The hinges weighed 12 lbs with the springs. The hood surprisinly only weigh 65lbs. But that is a total of 77 lbs vs a total of 30 lbs for the aluminum hood and hinges. So a decent savings.
CamaroAJ
03-03-2011, 07:06 AM
1st gen camaro
AMD aluminum 2" cowl hood: 21lbs
critter
03-03-2011, 07:12 AM
Great thread. So what's a light weight alternative for us second gen Trans Am guys who have that big stinking hole in our hood? I don't think I can afford one of Albert's carbon fiber creations but I'm sure that's the ultimate weight savings. Anyone make a FG one that works with hinges or are they all pin on?
Skip Fix
03-13-2011, 10:04 AM
Critter I think the old Mecham Macho TAs had a bolt on 'glass hood but used pins instead of latches on the front end.
I don't think my 78 hood weighs as much as John said his weighed as I can pick it up and move it around fairly easily by myself-now the 65 GTO hood is a WAY different story.
1969CamaroRS
03-13-2011, 10:12 AM
1st gen camaro
Carbon fiber Cowl hood 17lbs (Anvil Auto's) :naughty:
