View Full Version : 2nd gen camaro.....17x9 fronts????
musclecarmatt
01-23-2011, 07:28 PM
Hey guys...I want run 17x9 front and 17x9.5 rear on 70-73 camaros....think i would be a nice stance....anybody running this combo?...or just the fronts and what tire size??https://static1.pt-content.com/images/pt/2007/05/confused-1.gif
Matt
buickfunnycar.com
01-24-2011, 01:03 PM
Running a 9" front wheel may limit your turning radius inward Matt...I'm thinking a 17x8 (4.75" b/s) with a 255/45 tire would fill the wheelwells up quite nicely...
Jeff70
01-24-2011, 02:00 PM
Didn't the Hotchkis camaro run 17x9 1/2 & 11's with a stock front sub and the factory wheel wells. If I remember correctly the Spectre Performance camaro the lime green 2nd gen that was previously built by Cam from Optima also is running a 17x9 1/2 you could check into to those and see what you come up with.
http://www.spectreperformance.com/#CARS
http://chevyhighperformance.automotive.com/10016/56518-1971-chevrolet-camaro-z28/photos0-0.html
Jeff70
01-24-2011, 02:08 PM
Here's a pic of Cam's Camaro at Buttonwillow
http://www.racehome.com/images/otd11camdouglasparked.jpg
SLO_Z28
01-24-2011, 03:32 PM
You can fit a 9 inch wheel no problem with the right backspacing, depending on how low your front it. The green car has a 9.5 and you can see where it ends up, if it was as low as my car it would come down on the fender. Like john said a 8 inch wheel with a 245 fits very nice and wont rub. You can easily fit a 17x10 on the back so a 9.5 is fine.
musclecarmatt
01-24-2011, 05:40 PM
i thinking about that too john.......same specs...i think that be just right cause my lowered about 2 1/4 in the front....
