    Results 1 to 8 of 8
      FL and Calif.
      Widest front wheel size on 2gen firebird ??
      I am helping my cousin with hes 73 Firebird project and he will use stock front A-arms with drop spindles. What could be the widest front wheel when using 18" or 19" wheels??
      Sep 2004
      Orlando, FL
      Taller 255/45/18s on mine... others are running 255/40/18s with no problems. HTH
      SMSgt Ty Ingle, USAF
      "CF71" - Freedom Bird
      FL and Calif.
      Thanks for the input. I was hoping for to use 9.5" x 18" At front.Is that impossible?
      Rockford Illinois
      my 285 40 17" Kumho's are the exact same size as my 255 50 16" were.
      So you have to really look into the tire manufcture to get the max width.
      SoCal
      9 inch wheels are certainly possible (and common.) I'm not sure about 9.5" wheels, but I'm sure it's been done.
      Brett H.
      1979 Pontiac Firebird Trans Am
      1991 Mazda Miata
      2005 Ford Mustang GT
      1987 Ford Mustang GT - Sold 06-29-2014
      1988 Oldsmobile Cutlass Ciera - RIP 9-17-2011
      1992 Chevrolet Corvette - Sold 10-12-2017
      Apr 2004
      OKC, OK
      8" if you want the wheel inside the fender lip
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Jan 2010
      Delaware
      I disagree that 8" is the max to keep the tire in the wells.........look at Year One's snowflake and honeycomb wheels....
      They are both 17x9.....one has 4 7/8 BS, the other has 5". Both sets are meant to run at all 4 corners of a 2nd gen bird, earlier or later with stock suspension. Look on their website or over on PY for pics of peoples cars with these and they are not sticking out. Plenty of people running as much as 275's even on the front.
      In fact, many people go wider with a bit more backspacing even on the front. Worst case scenario is modifying the stop a bit so that on hard turns you dont rub the swaybar.
      1973 Trans Am 455 SR block, ported 6x-8 heads, solid cam, Victor intake, 830 CSU carb, aluminum rods, 77mm Garrett turbo and methanol injection. 1064hp at the flywheel@5500 rpm
      Aug 2006
      austin
      Ditto what he said^^^
      Greg
      1976 Trans Am SacrilEdge
      twin turbo 455
      Ttops and 4spd
      one of 110 made
      https://www.pro-touring.com/showthre...ect&highlight=
      https://www.pro-touring.com/showthre...ilEdge-is-free!
