View Full Version : 1962 Impala build
swedester
12-15-2010, 01:31 PM
thought Iīd put up a build thread of my beat up 62 Impala,the car has been hit hard on the drivers side in an accident many years ago,and at some point someone thought it would be a great idea to make a "new body" for it out of bondo:wasntme:and when the bondo started to crack and fall off,someone decided to strip it down and do a resto,to make a long story short,that failed and the car became a donor car.and thatīs were I came in to the picture,I traded some free stuff I had for the carcass,and dragged it home,itīs missing all glass,all crome,all interior,drivetrain,well,you get the picture.
the body needs new rockers,new floors,right qrtr panel,new trunklid and hood,and I allready got a fresh driversdoor and driverside fender for it.
plans were vague for starters,but when I found a 2002 8.1 litre vortec engine,the plan started to form,I soon realized that the oem frontsuspension needed everything replaced and uppgraded,I got a 86 c4 z51 frontend off ebay,and got it shipped to sweden.
thatīs about were Iīm at,I also ordered some wheels for it,but they wonīt be here until mid/late Jan.
now on to some picīs off my Impalaish pile of wrinkled steel:screwy:
https://static1.pt-content.com/images/pt/2010/12/100_0189jpgforwebxlarge-1.jpg
after second nite scraping and cursing
https://static1.pt-content.com/images/pt/2010/12/100_0232jpgforwebxlarge-1.jpg
engine fresh out the junkyard low mileage out off a wrecked ambulance
https://static1.pt-content.com/images/pt/2010/12/100_0233jpgforwebxlarge-1.jpg
cracked watercrossover,I will probably fabricate a new one out of aluminum,need to shave every possible ounce of this beast
https://static1.pt-content.com/images/pt/2010/12/100_0556jpgforwebxlarge-1.jpg
z51 frontend still wearing the old framerails
https://static1.pt-content.com/images/pt/2010/12/100_0574jpgforwebxlarge-1.jpg
mocked up at desired ride height,give or take 1/2"
https://static1.pt-content.com/images/pt/2010/12/100_0575jpgforwebxlarge-1.jpg
well,not much going on here yet,need to fixate the frame square and level to the floor before I start cutting.
coolwelder62
12-15-2010, 03:41 PM
Cool project.Cant wait to see some update's.
CruizinKev
12-16-2010, 08:44 AM
very nice project! I love the impalas!
lilbuzzy
12-16-2010, 09:03 AM
What will you take for the scooter in the background?
swedester
12-16-2010, 09:38 AM
a little more info:the wheels I ordered are aero racing wheels series 50,in gloss black,10x15" fronts,12x15" rears,also ordered tires;m/t sportsman s/r,12x26x15 fronts,15x29x15 rears,a little to much sidewall for a cornering monster,but I just had to have the nascar wheels!,as for clearance of the front suspension with a 10" wide 15" wheel,I will have to tweak the caliper some,and remove the greasefitting on the lower balljoint.
transmission wise,Iīve decided on a t56,probably will get a used viper unit,and make it work with as much own fab as possible,if it blows,Iīll get the keisler dog box kit for it.
I will probably use a 9" rear,but with strangeīs 12bolt drop out,just to keep it a little more gm(and to get less friction/hp rob)
not decided on what rear supension I will use,but probably home made K-link style.
the engine will creep back a few inches too,not decided on how much,or what style the firewall will get,but Iīll figure it out.
updates will probably be far inbetween,as Iīm both lazy and poor:rotfl:
swedester
12-16-2010, 04:07 PM
got the vette framerails off,and started removing the old engine stands,and spent the rest of the evening cleaning/organizing my garage.
https://static1.pt-content.com/images/pt/2010/12/100_0576jpgforwebxlarge-1.jpg
swedester
12-19-2010, 03:52 PM
mini update:removed the old oilcooler lines from the 496,and got some more paint on my garagewalls.
jake8092
12-23-2010, 08:43 AM
Cool, A friend of mine is building a 62. We built a 70 for him back in our High school days...Sweet project!
swedester
01-03-2011, 02:51 AM
https://static1.pt-content.com/images/pt/2011/01/100_0627jpgforwebxlarge-1.jpg
got the body off,and the frame back inside.
https://static1.pt-content.com/images/pt/2011/01/100_0629jpgforwebxlarge-1.jpg
rear part of frame is toast,but I planned on making new rails out back anyway.
https://static1.pt-content.com/images/pt/2011/01/100_0628jpgforwebxlarge-1.jpg
body out in the cold...
https://static1.pt-content.com/images/pt/2011/01/100_0631jpgforwebxlarge-1.jpg
cleaned up the garage,and cut off the frame horns,next is drilling the floor for some fix points.
lnirenberg
01-03-2011, 04:01 AM
Very cool. If you PM me your email, I have an article from Muscle Car Review on stiffening the X-frame. The files are too large to post and I have no idea how to make them smaller.
lnirenberg
01-03-2011, 06:14 PM
I got a bunch of requests for the article which I sent, but it would be a lot easier if someone on the site knew how to reduce the size of pdf files. I have a sheet scanner so each page is a separate file almost 1mb each.
61ragtop
01-03-2011, 07:21 PM
I found this after I got your email with the article........
http://www.streetrodderweb.com/tech/1002sr_how_to_stiffen_your_chevy_frame/index.html
Motown 454
01-03-2011, 07:26 PM
Nice project!
Conrad283
01-03-2011, 09:47 PM
I think that's an awesome picture ...
swedester
01-04-2011, 12:36 PM
got this up on my wall today,itīs from the 1961-62 gm shopmanual,blown up to a decent size and laminated to last a long time.it was expensive though...
but it will save lots of time,as I donīt need to move away from what Iīm doing to check the drawing.
https://static1.pt-content.com/images/pt/2011/01/100_0632jpgforwebxlarge-1.jpg
MrBlonde
01-04-2011, 08:16 PM
Go the fullsize!
swedester
01-28-2011, 01:42 AM
well,today my front wheels and 4 tires showed up from summit,and,sadly,both rims were dameged due to poor packaging from the manufacturer,one rim was pretty scrathed up,and the other one even bent slightly,and it was repacked at summit(said so on the sticker)so they saw the bent rim,and repacked and sent out,NOT what I expected from summit,been in touch with customer service already,and I will post up the result here,I really hope they solve this in a nice and timely manner,I donīt want my project to be held up another month waiting for new rims to arrive with sea freight.
David Sloan
01-28-2011, 07:19 AM
sorry to here the set back, But this is a cool project! cant wait to see more!
swedester
01-28-2011, 10:57 AM
soo...summitracing blames the shipper,even though itīs obvious that the damage occured before the boxes were packed together as one unit(no damage on the summit stickers etc) so this looks like it will turn in to a nightmare,I wish I photographed the pallet before I opened it up,damn...
swedester
01-30-2011, 10:27 AM
well,trying to see beyond the damaged parts,and test fit and plan the rest of the build.
https://static1.pt-content.com/images/pt/2011/01/100_0689jpgforwebxlarge-1.jpg
https://static1.pt-content.com/images/pt/2011/01/100_0690jpgforwebxlarge-1.jpg
https://static1.pt-content.com/images/pt/2011/01/100_0694jpgforwebxlarge-1.jpg
https://static1.pt-content.com/images/pt/2011/01/100_0695jpgforwebxlarge-1.jpg
https://static1.pt-content.com/images/pt/2011/01/100_0696jpgforwebxlarge-1.jpg
https://static1.pt-content.com/images/pt/2011/01/100_0697jpgforwebxlarge-1.jpg
https://static1.pt-content.com/images/pt/2011/01/100_0698jpgforwebxlarge-1.jpg
https://static1.pt-content.com/images/pt/2011/01/100_0699jpgforwebxlarge-1.jpg
racedaddy
01-30-2011, 07:18 PM
That's some nice lookin' tires. Lots of meat!
ramlinman
02-05-2011, 04:13 PM
this should be a nice build keep the pictures coming
