Results 1 to 5 of 5
11-25-2010 #1
Moser 9" for 67 Camaro - LS1 brakes?
I found out my 8.5 10 bolt is out of a 2nd gen camaro and is too wide for my taste.
I'm considering a Moser 9" direct replacement housing. If you've done this swap, what brakes did you use on the rear? Can I use LS1 rear brakes on it? I know the Currie unit from Jegs uses the 2.50" brake spacing like a GM, not sure about Moser. Just not sure if the large bearing ends on the 9" will allow the use of them.
Either way, any recommendations? I have 12" C4 brakes on the front with single piston calipers.
