View Full Version : opti spark
paul67
11-20-2010, 03:55 PM
Can you use the dissy cap and rotor from a 96 onto a 94 as i ordered the wrong 1 doh.
DynoDon
11-20-2010, 04:29 PM
NOPE, 92-94 are one type, 95 and later are different
gkring
11-20-2010, 05:33 PM
The later ones are just vented but will bolt on. Some guys convert their earlier optispark to be vented and use the later model cap. Personally I would do the conversion and keep the later cap. The optispark need all the help they can get.
http://www.fierolt1.com/lt1_95_up_OptiReplace.htm
http://www.corvettefever.com/howto/16758/index.html
paul67
11-21-2010, 04:50 AM
You mean still drill out the holes on the early body and vent and still use the later cap as part on the mod.?
gkring
11-21-2010, 07:18 AM
yes, one vent is on the cap and the other vent is in the body on the later models. Your early opti just has 3 holes in the body to act as a drain. keep the cap and do the mod to the body to add a vent tube and fill the other two holes.
paul67
11-21-2010, 09:42 AM
Thanks will do
