View Full Version : Just lost ALL power.
1BAGTO
11-18-2010, 07:19 PM
I haven't had a chance to look into my problem but just wanted some suggestions.
I started my car up tonight and had it warmed up and was pulling out of the driveway. Backed out of the garage and EVERYTHING went dead. I don't even have dome light power. Checked the battery, no problems, have a good ground. I am suspecting either ignition or a blown fuse somewhere. The car has a painless wiring harness if that sheds any light at all. This is the first time that I have had any ignition/power related issues whatsoever. Please, any suggestions would be great!!
Larry Callahan
11-18-2010, 07:47 PM
Fusable link?
1BAGTO
11-18-2010, 07:58 PM
Would you mind explaining exactly what fusable link refers to. Is it a relay or an actual in-line fuse?
81S
11-18-2010, 08:13 PM
Check the battery terminals first. if you burned a ground or there is any corosion or loosenes this could be you problem. You could have burned either of the battery leads on a header(speeking from experience.) next check you starter wires dow at the starter. if the bolt is loose on the starter you could have the same problem. i hope you at least have a test light.
6'9"Witha69
11-19-2010, 08:41 AM
Primary wire from Battery to junction block gone. I meted one once and it kills everything but the Battery still looks good.
sik68
11-19-2010, 08:53 AM
+1 on the fusible link or other wiring directly at the horn relay or junction block behind the battery. I have experienced exactly what happened to you. Car is fine, then all of a sudden, no nothin'. No headlights, starter, etc. Turns out I had a bad connection right at the horn relay, which carries all the power to your headlights and interior of your car, including the ignition switch.
1BAGTO
11-20-2010, 03:36 PM
Thanks for all of the replies fellas! Got the problem fixed today. It was a blown interior fuse behind the battery. Thank again to all that replied!!
kochevy67
11-20-2010, 03:50 PM
Now you should find out what caused this so it doesn't happen again.
1BAGTO
11-20-2010, 04:17 PM
It was a short in the headlight switch.
