Results 1 to 3 of 3
Thread: Painless Camaro 67 DIMMER SWITCH
05-28-2005 #1
I rewired the car, didn't get any headlight action, checked fuses, wires, connections, grounds, headlights , and switch - all work fine. Finally found a clue at the fuse box, a Dimmer Switch connector with wires that I didn't use.
I didn't have a dimmer switch to start with. Did 67 Camaro's come with them factory? Will I HAVE to have a dimmer switch? I don't know what it does because my instrumental lighting is dimmed through the Headlight Switch.
Thanks For Reading!1967 Chevrolet Camaro 350/350
1962 Chevrolet Chevy II 400 194/PG
05-28-2005 #2My 67 camaro came with a dimmer switch so I assume all did. It is down by your left foot, on the floor, below the emergency brake pedal. It is a push type of switch. It switches the headlights from low beam to high beam.
Mike
05-28-2005 #3oh man i'm a dork, the dimmer switch was all i needed to solve all my woes. thanks!
