View Full Version : What backspacing on 18x9 for 68 Camaro stock susp?
GOAT756
11-10-2010, 11:24 AM
What backspacing do i need for an 18X9 on a 68 camaro stock ride height. Budnik wheels do not offer 18X9.5 in fat lip wheel so i would like to run and 18X9. thanks
ProdigyCustoms
11-10-2010, 01:19 PM
On the front or rear? I assume the rear because you mention a 9.5"? 5" is perfect
68Formula
11-10-2010, 01:53 PM
From what I understood, a 5.5" is in most cases (always a tiny bit of variance car to car) optimum for a 9.5" rim. So wouldn't a 5.25" be optimum with a 9" rim (to center the tire)? I've had the same question myself because not every wheel manufacturer carries a 9.5.
Damn True
11-10-2010, 02:02 PM
Did you check here?
https://www.pro-touring.com/forum/showthread.php?1008-Pro-touring.com-s-Wheel-fitment-database
ProdigyCustoms
11-10-2010, 02:09 PM
You want to protect the front space to keep the relashionship between the tire and quarter panel looking right so it does not have that sucked in look.
JustinB
11-10-2010, 02:45 PM
We run 5.25" on 9's and get creative with pad length depending on brakes to maximize wheel lip. Seems to be the sweet spot. Allows customers to run low without rubbing and does not suck the wheel into the center of the car.
