    Results 1 to 18 of 18
    Thread: Coys Wheels C-5
      Jun 2005
      Coys Wheels C-5
      Hello
      How is the quality of coys wheels?
      Any recommendations yes/no?
      I'm not what wheels to buy. And how much I want to spend.
      Rob
      bowling green,ky
      not bad for the money. I had some 20/18s on my 69 camaro for couple of years. They are just about as widespread as boss 338s but i like the coys better. just my 2 cents.
      Oct 2006
      Phoenix, AZ
      I'd be more content with them if it weren't for the stupid valve stem placement. Doesn't play well with big brakes...FYI
      Jeff K.
      69 Camaro SS, 406 SBC, TKO600, 9" w/3.73 tru-trac, Speedtech Arms, AFX Spindles, Lee 670 Box, Baer GT front, C5Z rear. Hyperco Leafs w/ Fays2 Watts Link + Varishocks.
      Wake Forest,NC
      Quote Originally Posted by jknight16 View Post
      X2 on the valve stem arrangement with big brakes and they leak like crazy.
      May 2007
      Can you elaborate? I was just contemplating placing an order for the C-55's - 17X8, 4.5"bs @ $125 each - Can't beat that price!
      Tim
      '65 2+2
      347 - RetroTek EFI - 471 fwhp
      JBA shorty's, 2.5" tubes, Dr Gas X-pipe
      T-5 world class 5 speed, w/ .80 OD
      9" with 3.70's & T-loc
      4 wheel disc brakes
      17" Torq-Thrust D's, 225/45 & 245/45
      TCP/Global West suspension
      OpenTracker roller spring perches
      subframe connectors, Traction Masters, Panhard bar
      TCP manual rack & pinion
      power windows & power door locks w/ keyless entry
      Mar 2010
      South Central Ky
      They place the valve stem on the inside of the wheel usually hidden behind a spoke. They also use the flush mount valve stem. I've had mine C-55's for about a yr. now with no leaks. I don't have big brakes so I can't elaborate on that. Very good for the money though.
      Central Illinois
      The quality of the aluminum on the C5s is junk. They don't polish up worth sh*t!
      '68 442 convertible
      5 SPEED - EFI
      '66 442 Hardtop
      in process
      Jun 2005
      Thanks Guys
      Wake Forest,NC
      Quote Originally Posted by 65 Fastback View Post
      Tim
      The flush mount valve stem is placed inline with the rotor and requires a special inflation tool, if you use 18" or smaller wheels and 13" or larger brakes it is very tricky to put air the tire which you will have to do regularly because the valve stems leak. I have 5 different cars with coys wheels and every one of them has at least one valve stem that leaks. There are different length inflation tools, so get the shortest one they make or you'll be taking the wheel off to put air in the tire with big brakes.
      May 2007
      Talked with Coy's and they have relocated the valve stem location. I went ahead and ordered a set of C-55's, 17X8, 4.75" bs. They showed up this week, I checked them, test fit them and got my race rubbers installed.
      Tim
      '65 2+2
      4 wheel disc brakes
      Jun 2009
      I love my C5's but also have the same problem with airing my fronts. They are 18's with large drum brakes.
      May 2007
      Received my new Coy's C-55's - 17" X 8", 4.75" backspacing. Notice the new position of the valve stem.
      '65 2+2
      4 wheel disc brakes
      Jan 2009
      Those look great.
      Better than the pics on their website!
      Good luck w/your project.
      Washington, MO
      c55's look awesome.
      San Antonio, TX
      Now that's sexy right there!
      Your Mustang looks fantastic BTW
      Dave
      May 2007
      Quote Originally Posted by mc84_zz4 View Post
      Thanks!
      '65 2+2
      4 wheel disc brakes
      Aug 2012
      any picts with the tires on?
      They did not move them on the C5 wheel and have no plans to do so.
      Mike
      86 Buick GN, Stage 2 V6, Twin EFR Turbos
