View Full Version : pcv catch can
69projectKAOS
11-01-2010, 04:51 PM
is it OK to run a pcv catch can on a naturally aspirated motor? im thinking about fabbing one up on my own. thanks-dom
11-01-2010, 08:22 PM
sure, even NA's can have blow by and oil vapor.
CamaroAJ
11-02-2010, 09:13 AM
thats like mod #1 on LSx series engines. so yes.
69projectKAOS
11-04-2010, 07:52 AM
good lol because i made one out of some old material i had laying around and it came out better than expected so i really wanted to use it! thanks guys -Dom
BOBBYA312
11-27-2010, 09:11 PM
A little mist/vapor is normal.
JRouche
12-13-2010, 11:13 PM
Here is my PCV catch can(s). Its pulling off a vacuum from the throttle body to a GM truck PCV valve. The valve is just a simple lil hole (looks to be 1/8", no moving parts) into a canister that vents from the right side valve cover. The air supply comes from the left side valve cover thats routed to the same type of canister as the vacuum side. But its topped off with a filter to filter the incoming air for the crank case.
I used a canister for the incoming air side because sometimes there is an over pressure sitch where the left side also vents OUT and its not complety a source of fresh air but sometimes is a vent outward.
Dont know why it vents out sometimes, its a fresh engine and there is plenty of vacuum on the right side to pull the vapors out. But sometimes I do get a venting out from the left side. So the canister keeps any fluids out of the engine compartment.
So I have two aluminum containers. One for the vacuum side and one for the vent side. So far so good. JR
