View Full Version : Alternator brackets Q? .. Difference in dimension
BumpaD_Z28
10-07-2010, 02:08 PM
So I'm fighting an Alternator belt squeal at upper RPM's (about 4600-5400 redline) on my BBC in a 1967 Camaro. Alternator is mounted top of passenger side head (69+ style NOT 67 location), with a CHEAP chrome bracket on top, and the factory mounts for the rest ...
I already have a tried a HUGE pulley on it (5") too slow it down and that didn't do the trick ...
Question is between these too aftermarket brackets there is a 3/32" rear spacers dimension difference ???
.. I'm thinking that the MARCH one would put my belt "slightly" more inline as it look just barely too far forward now
March:
http://www.marchperf.com/instructions/Chevy%20Small%20Block/20125_instuctions.pdf
Billet Spec:
http://www.billetspecialties.com/assets/pdf/754.pdf
THOUGHTS ?
THANKS! ~DaVe
BumpaD_Z28
10-09-2010, 09:45 AM
chirp, chirp, chirp ...
Ok so does anyone run anything besides stock alternator brackets ?
~DaVe :cheers:
10-09-2010, 08:49 PM
how is your belt angles and gaps? pictures?
Lowend
10-10-2010, 07:37 AM
The real problem is probably flex. Those chrome cheapie brackets flex a lot when you stress them.
The best brackets I have found (by far) are Alan Grove
http://www.alangrovecomponents.com/Catalog.htm
https://static1.pt-content.com/images/pt/2010/10/118L218R-1.jpg
BumpaD_Z28
10-12-2010, 10:34 AM
Well I don't have pics yet, BUT I do think FLEX maybe the issue as mentioned above ...
I ended up ordering the SUMMIT brand (cheaper) after talking to their tech line they gave me a confirmation on the 3.25" dimension ...
http://static.summitracing.com/global/images/instructions/sum-420102.pdf
Hopefully we will see how it works by the end of the week :)
~DaVe
BumpaD_Z28
10-18-2010, 06:49 PM
Well I'm happy :) this summit bracket and a 7480 belt from checkers and no more belt squeal, now I need a lower RPM module in the MSD as I'm not short shifting for the belt, and the BB doesn't really have the parts to get the 6k chip ;)
https://static1.pt-content.com/images/pt/2010/10/sum420102_w-1.jpg
~DaVe
