Results 1 to 7 of 7
05-20-2005 #1
How to straighten steering wheel after new steering box
Today I installed a new close-ratio manual steering box, but now my steering wheel is about 1/2 turn off. How do I straighten it up? The wheel itself is 'keyed' by the horn switch. Do I have to straighten it, by adjusting the inner/outer tie rods?
Dan
05-20-2005 #2Correction, the wheel is 1/4 turn off, so I can't fix it at the rag joint.
Dan
05-20-2005 #3
- Join Date
- May 2003
- Location
- St. Charles, Mo
- Posts
- 424
Steering wheel
Are you sure you can't remove the steering wheel and reinstall it at the correct position? The horn switch should moveto wherever you need it. I don't have a factory column in my Nova but it is a GM column from Flaming Rivers.
You should steer from lock to lock and find the center of that travel. You could do something similar to a degree wheel for a cam. At that point, remove the wheel and install it in the correct position. Then align the front wheels relative to the rears with the steering wheel in its 12:00 position.
If you have an aligner availible with a means to measure steering angles from lock to lock, then you can check and make sure you have equal travel from left to right. You don't want to just adjust the tie rods to compensate for the offset wheel because you will have a differnce in max steer angle from side to side.
There is a way to measure max steer with strings and a tape measure. If you want to do that let me know and I'll try to explain it or come up with a pics showing how.
DLinson
05-20-2005 #4D,
It's a factory column and my horn switch rotates with the main shaft inside the column. My steering wheel has a hole where a portion of the horn switch passes through so I have to line up the steering wheel with that hole, thereby putting the wheel out of alignment. I'll take another look at it to see if there's another way to adjust the horn switch.
Otherwise I've looked at this from every different angle, stuff like:
- re-alignment at the rag joint, but the rag joint can only be at two different positions (180 degrees from each other)
- re-alignment at the pitman arm, but the pitman arm is keyed every 45 degrees, and that will rotate the wheel to the other side if 12 o'clock
I didn't really consider that fact that adjusting the tie rods to compensate for the offset wheel because you will have a difference in max. steer angle from side to side, but I really can't think of anything else that will help.
Dan
05-21-2005 #5
