    Results 1 to 12 of 12
      Aug 2010
      Widest wheels and tires
      hi to all , what is the widest wheels i can get on my camaro 1970
      Last edited by yousef; 09-18-2010 at 11:29 AM. Reason: widest wheels for camaro 1970
      Quote Originally Posted by yousef View Post
      Search is your friend. Try the wheels and tires section.....
      We've put 8s and 10s on lots of 2nd gen Camaros in various diameters with great results. Diameter is just a matter of budget and personal taste but the 8s and 10s are what you need to keep in mind regardless of diameter.
      Jason
      Aug 2010
      i am thinking of boze ZE wheels for my car what do you thenk ......
      Jan 2009
      Van Nuys, CA
      Hi. I have a 1970 RS/SS I am running 18 by 8.5 in the front and 20 by 9.5 in the rear. If I had measured better and if they offered wider tires at the time I could have gone to a 20 x 11 in the rear. I am also running global west control tubular control arms in the front with hotchkis suspension all around. If you want more details you should check out NASTYZ28.com it is a sec gen only camaro website.
      Mike
      Aug 2010
      Search is your friend......thanks
      from car craft
      Fitting Tires and Wheels ????
      17-inch: 17x9 with 5-1/2-inch backspacing front and rear. There may be lower-control-arm contact with some steering gears. Use tires with an aspect ratio of 40 or less and section widths of 245 to 255.
      18-inch: 18x9 with 5-1/2-inch backspacing front and rear. Use tires with an aspect ratio of 35 or less with section widths of 245 to 255 in front and 275 in the rear.
      Jun 2005
      Greenwood, SC
      I have 19x9.5 and 19x12 under mine no problem.
      Oct 2006
      Corona, CA
      9s on the front and 10s on the back, 265 front tire and 295 rear tire
      Aug 2010
      from car craft
      SIZES
      15"
      FRONT
      15" REAR
      16"
      FRONT
      16" REAR
      17"
      FRONT
      17" REAR
      18"
      FRONT
      18"REAR
      BACK
      SPACE
      4.5"
      Camaro = 5"
      Firebird = 5.125"
      4.5"
      Camaro = 5"
      Firebird = 5.125"
      6.0"
      6.0"
      6.0"
      6.0"
      RIM
      WIDTH
      8.0"
      Camaro = 9"
      Firebird = 10"
      8.0"
      Camaro = 9"
      Firebird = 10"
      9.5"
      Camaro = 10"
      Firebird = 11"
      9.5"
      Camaro = 10"
      Firebird = 11"
      TIRE
      SIZE
      255/55
      285/55 or less
      255/50
      285/50 or less
      265/40
      315/40 or less
      265/30
      315/30 or less
      Oct 2005
      Toronto
      I run 17x8x255 up front and 17X11x315 out back on my 72 RS,,,, the wheels are a tight fit and lowering can be an issue (resolved that buy bulging the rear quarter 1 1/2")
      My 73 TA runs 18x8x255/40 and 18x10x275/35 on Rushford Live wires no mod's......
      Carbon Kustoms Limited
      A.K.A. Albert from Toronto
      Wake Forest,NC
      It really depends on the ride height and if your willing to modify the body/wheel wells. I know there is no way a 10" wheel will fit on the back of mine as low as it sits without some surgery. Fwiw you can fit more tire on a bird than a camaro because of the shape of the wheel opening.
      Aug 2012
      The 4-1-5
      Quote Originally Posted by 65MALI View Post
      smarty pants
