View Full Version : sandblasters?
astross89
09-15-2010, 05:05 AM
Before we start I know all about harbor freight. Just my budget is super small. So that being said, is the a performance difference between these two? One work better on smaller compressors? They look to do the same thing just seal different and filling on one looks easier. Please help. Thanks
http://www.harborfreight.com/90-lb-pressurized-abrasive-blaster-with-easy-fill-top-load-lid-93889.html
http://www.harborfreight.com/110-lb-pressurized-abrasive-blaster-95014.html
317millhand
09-15-2010, 11:33 AM
I use the second one, but it does take a good compressor to keep up. The blaster works great, but just make sure to filter your sand before putting it in the tank or youll spend lots of time taking it apart. The little hood that it comes with sucks, so just throw it in the trash and buy a decent hood from Ebay or somewhere. I cant comment on the first one, but the one I have works excellent with DRY FILTERED play sand.
BLWN1
09-16-2010, 01:41 PM
Do you use it quite a bit? or occasionally? Good info to have, I need a cheap one.
317millhand
09-16-2010, 06:46 PM
Mine is only used occasionally. I really dont think any of the cheap blasters are made to be used everyday. The nozzles do wear out after a few hours but are cheap to replace.
BLWN1
09-16-2010, 08:11 PM
Im not looking to be professional, just save some money over out blasting con-artist.... ;)
67 455 Bird ragtop
09-20-2010, 05:43 AM
If you do buy from HF look through most of the current magazines, Car Craft, Hot Rod, PHR, etc ... most have ads in them and a 20% coupon.
astross89
09-20-2010, 08:12 AM
thank you I have a ton of them.
