View Full Version : wilwood master
$Mike70Z-28
09-04-2010, 04:14 AM
need to know ? the wilwood master has 4 ports can i use the 2 for the front brake lines so wont need to use the tee
wmhjr
09-04-2010, 04:28 AM
There have been a couple threads about this, but as I recall the answer is yes.
$Mike70Z-28
09-04-2010, 04:44 AM
trying to find threads but cant find them......... thanks
staged67gspwr
09-06-2010, 04:25 PM
ttt
LONE*STAR
09-07-2010, 01:43 PM
I did hope it's fine
protour73
09-07-2010, 03:46 PM
I think the ultimate answer to this question requires a call to Justin or someone else at Wilwood's Tech Support.
Based on the information in the instructions that come with each Tandem Master Cylinder you have to take away that only one can be used:
Two hex head plugs are
supplied to block the unused outlet ports. Pressure may be taken from either side of the master cylinder.
• Connect one of the primary outlet ports (A) to the brakes at the end of the vehicle with the greatest total effective piston bore area.
On most vehicles, this will be the front brake line (see note next page).
• Connect one of the secondary outlet ports (B) to the brakes at the end of the vehicle with the lesser total effective piston bore
area. On most vehicles, this will be the rear brake line (see note next page).
Just for an example go through the Engine Picture thread, you'll not find one Wilwood Tandem Master with both ports plumbed for the front brakes https://www.pro-touring.com/forum/showthread.php?t=60345
$Mike70Z-28
09-07-2010, 04:50 PM
thanks protour
dipren443
09-07-2010, 05:40 PM
The Tee makes it alot cleaner. I can take pics of what I am running if you are curious. I am using the Wilwood tandem master with an adjustable prop valve on a 2nd gen.
staged67gspwr
09-07-2010, 07:31 PM
Yes i`d like to see a pic if possible.
Hey Mike you order the pinion yoke yet?
dipren443
09-08-2010, 04:49 AM
I will snap pics of the lines tonight. Engine is out currently so I should be able to take good pics.
$Mike70Z-28
09-08-2010, 07:16 AM
yes lalin
staged67gspwr
09-08-2010, 07:18 AM
yes lalin
Ok Saso,lolol
protour73
09-08-2010, 03:55 PM
This is what I ended up with after installing my Hydroboost setup
https://static1.pt-content.com/images/pt/2010/09/IMG_3087-1.jpg
The Wilwood proportioning valve for the rear brakes
https://static1.pt-content.com/images/pt/2010/09/IMG_3093-1.jpg
absintheisfun
09-11-2010, 05:52 AM
Just so I'm certain here, you have one line out running to a "T" to the front and one line out running to a prop for the rear? I'm assuming you have another "T" at the differential?
Thanks!
