View Full Version : Proportioning valve re-location
69*Goat
08-27-2010, 01:18 PM
Guys, If this is not in the right sub-forum, I apologize.
I am running headers on my 69 GTO, and I have succeeded in cooking my brake proportioning valve that sits on the frame about 1.5 inches from the header. I know, I should have moved it previously, but I didn't. What is the best way to re-locate it. I have already replaced all of the hard lines back when I did a frame off 3 years ago. I really don't want to have to run all new lines. What have you guys done, and where have you GM a-body owners re-located your prop valves to. Do you have pictures?
Thanks in advance
RW
novaderrik
08-28-2010, 06:21 PM
can you just fab up a simple heat shield out of some sheetmetal to keep the radiant heat away from it?
Roadbuster
08-28-2010, 10:17 PM
If you are talking about an adjustable prop valve, I made a simple bracket and mounted it to the frame under the driver's seat. For tuning it is easy to get to and out of the way.
Mingus
09-04-2010, 05:17 AM
We moved the whole assembly up under the MC on my wifes' car since it has a 455 with headers. We installed all new "conversion" lines from Inline Tube that are made to work with the new prop valve location. I believe you can get just the lines to run from the old location to the new one (since you just replaced them).
Hope this helps.
http://s957.photobucket.com/albums/ae53/Mingus1966/?action=view&current=LeMansMC.jpg
