View Full Version : Windshield Mount Rear View Mirror with Compass
ModernMuseum
08-23-2010, 08:14 AM
Anyone know of a vehicle that has one of these? I'd like to get an auto-dimming mirror that mounts to the windshield and has an internal compass. I'm guessing the wire would run up through the windshield molding and back down the A-pillar. Preferably something under $50.
CamaroAJ
08-23-2010, 08:59 AM
4th gen camaro, 02+ GM trucks, impalas, most buicks and caddys.
ModernMuseum
08-23-2010, 10:52 AM
Sweet, thanks. Do you know if the memory for the garage door openers, if they have it, is inside the mirror itself or is it connected to an external ECU?
Also, a company called GENTEX apparently makes these and is a popular vendor for them in other communities.
CamaroAJ
08-23-2010, 11:20 AM
depends on the car, if the buttons are in the mirror then its all in there. most of GM's garage door buttons are in the sun visor though.
BonzoHansen
08-23-2010, 03:19 PM
lights only on the 4th gen mirror unless there was an option at the end or the run I'm unaware of. I put one in my 77.
toxicz28
08-29-2010, 03:44 PM
Ditto! My late '02 SS has map lights only, no auto dim.
Z06vet
08-29-2010, 04:08 PM
Hit the salvage yards and look around. I have a 4th gen mirror in my 67. I hope to use a 07-up GM truck mirror in my 69, but not sure whats involved with their wiring.
Scott
rlpj68
09-01-2010, 02:42 PM
most infiniti's and nissan upper scale cars have the auto dimming feature, i put one from an infiniti i35 in mine but the garage feature is also in the visor. i have looked at it and it would be pretty simple to retro into your visor if you are going to recover it.
Motown 454
09-01-2010, 07:49 PM
My 99 Tahoe has the auto dim compass and temp in it. I don't know if it needs an ECU to work?
EFI69Cam
09-02-2010, 08:19 AM
Look up Gentex mirrors on ebay plenty of sellers. Just paid $150 for a brand new one with auto-dim map lights and compass. Came with harness, sensor and the wire to turn the map lights on with the dome light.
TnBlkC230WZ
09-02-2010, 08:28 AM
Do you have pics of your install? I'm looking at one of these. I ran multiple wires to the mirror area of the headliner when I wired it, so connecting should be easy.
EFI69Cam
09-02-2010, 10:40 AM
I have only run the harness, it runs up the a pillar under the cover, then behind the windlace and comes out of the hole in the sunvisor holder where the original mirror's "arm" came out. The mirror will be mounted about 3-4" below there. I've held the mirror up with the harness plugged in and it looks factory.
No pictures yet, sorry.
Chevelle LT1
09-02-2010, 11:44 AM
+1 on the Nissan/Infiniti route. You can find mirrors with the garge door opener, compass, ambient temp display, and auto-dimming mirrors for pretty cheap. If you want the ambien display, be sure to get the temp sensor (usually located in front of the radiator).
