View Full Version : Idle Problem
nomurci
08-20-2010, 03:01 AM
Good Morning fellow muscle car enthusiasts.. i have an idle problem, when i cold start my car it dies unless i take off immediately... throughout the day it will start fine.. I have changed the mass airflow and idle speed sensor.. now im stumped.. its a 2001 pontiac trans am ls1... thanks for your help
08-20-2010, 09:06 AM
double check for bypass air from the mass airflow meter to throttle body and also check the throttle blades for carbon/oil build up. might need a cleaning.
was your battery disconnected recently?
nomurci
08-20-2010, 11:19 AM
i tried the battery idea we will see how it works in the morn when i cold start... ill check the other two in the morning as well... ill get back to you thanks!
