View Full Version : Preparing car
Z06killinSBF
08-12-2010, 10:42 AM
I'm about to take the voyage of driving my car from coastal Georgia to the DFW area in Texas. This is my "getting out of the Navy" drive home. I know I need to get the front aligned, trans fluid replaced, drive shaft balanced, oil changed, tranny fluid overflow canister made. Can anyone think of anything that should be addressed? I'm super siked out and my dad will be joining me. This should be fun!!
claytonisbob
08-12-2010, 11:02 AM
Welcome back to DFW!
NOT A TA
08-12-2010, 11:07 AM
AAA with the 100 mile tow upgrade. Peace of mind for road trips.
GrabberGT
08-12-2010, 11:13 AM
Not a bad idea...
But more importantly especially now... A/C charged. I dont know about coastal GA but here in DFW we've had some killer heat lately.
Oh... and welcome home. We still need to establish a strong PT community here.
oestek
08-12-2010, 12:13 PM
How long since it's been driven last?
406 Q-ship
08-12-2010, 12:37 PM
I would also check stuff like the lights, wiper blades (see if the wipers themselves still work), and check the condition of the brakes (including the lines). I look at a long drive just like taking the car to the track, nut and bolt everything. Better safe than sorry.
+2 on the AAA roadside plus.
Z06killinSBF
08-12-2010, 03:39 PM
I drive the car daily so the a/c is nice and ice cold. The whole braking system is only about 2 years old and was recently bleed. All the suspension will be gone over to ensure tightness and be greased. All lights work, except low beams (some kind of short).
kmcanally
08-12-2010, 03:43 PM
Cool...welcome back to Dallas. You will have to come out to the next Cars & Coffee.
Z06killinSBF
08-12-2010, 03:59 PM
I will be in McKinney on the 16th of Sep I hope. Anything going on that weekend?
Z06killinSBF
08-13-2010, 05:59 AM
I'm thinking of running something like this for my trans vent. The C4's have a tendency to puke fluid out of the vent so I plan to run a vented trap tank and mount it up on the firewall. Any ideas?
https://static1.pt-content.com/images/pt/2010/08/31NPWC0KF1L_SL500_AA300_-1.jpg
claytonisbob
08-13-2010, 06:20 AM
I've been thinking of building something similar for my PCV system using a Venom energy drink bottle (nice solid aluminum bottle), a breather like that, and a petcock from the hardware store. But that's me being cheap.
SatisTraction
08-13-2010, 07:00 AM
if you daily drive the car then change the oil and make sure you have a spare.
paul67
08-13-2010, 07:15 AM
Spare water ,engine oil, trans oil,belt, fuses,bulbs,phone charger,toilet paper,towel,torch,bottle jack ,instant tyre leak repair,post the site your route plan as you might be going past someone's house call in for coffee chat.Oh and have a good trip.
Z06killinSBF
08-13-2010, 10:20 AM
Hmmm... that is a GREAT idea!! :cheers:
69fbodyproject
08-13-2010, 10:24 AM
Im crazy, but after my cars have sat for any extended period, i always pull the plugs and check them after firing the car and letting it run for about 1/2 hour.
Z06killinSBF
08-15-2010, 01:38 PM
Well, I fixed some of those odds and ends stuff that has been bothering me for years and it only took like an hour. Low beam wire was pinched under a fender nut causing a short (fixed), the horns sounded like a dying cow so I bought a new hi side horn (fixed), my cheapy Sunpro temp gauge has been broken, bought a new one (fixed). I also had a nail in my pass front tire (fixed). I checked all my front suspension while I had it up in the air. All seems tight and clean.
Dan S.
08-15-2010, 02:42 PM
Make sure you pee before you leave the house.
Z06killinSBF
08-15-2010, 03:15 PM
Didnt think of that. Must make a note to self :spank2:
Mingus
08-15-2010, 04:00 PM
Check and/or change gear lube in rearend. It will get way hot on an extended trip if the lube is old and thin.
novaderrik
08-15-2010, 09:52 PM
sounds like there is nothing left to do other than hit the road.
Z06killinSBF
08-16-2010, 07:20 AM
I may get new rear tires, it needs an alignment (twitchy at speed) and possible drive shaft balance. I think everything else is good. I'm ready to roll.
