View Full Version : brake bolt ?????
stage2ROUSH
08-07-2010, 07:12 PM
So my car has the Baer rear rotor upgrade ( stock calipers) any way the top bolt the holds the caliper to the bracket decided to " dissapear" ?? don't ask how I'm not sure. I went to my local ford dealer and got new bolts, they are about 1/2 inch shorter than the bolt that is still there{ because of the bracket that extend's the stock caliper out} , you guys think maybe putting some locktight and the shorter bolt would be ok, or should I try and get the same length bolt ?????? thanks for all & any thoughts.
Steve1968LS2
08-07-2010, 07:19 PM
Kind of depends.. how much of the bolt is in the hole?
In other words does the shorter bolt go all the way though the threaded hole?
stage2ROUSH
08-07-2010, 07:22 PM
no, it looks like maybe half goes in
stage2ROUSH
08-07-2010, 07:23 PM
maybe a little more than half
stage2ROUSH
08-07-2010, 07:29 PM
the longer bolt stops even at the end of the threaded hole,
ArtosDracon
08-07-2010, 10:28 PM
Get the longer bolt, and make sure it's a grade 8 or better, 10.9 would be much better. Your brakes are one thing not to fool with. And I would blue locktite them too, I always do on brakes.
Steve1968LS2
08-08-2010, 08:02 AM
What he said..
That caliper bracket is under HUGE stress. I had a bolt work it's way out of my wilwood setup at Buttonwillow.. let's just say that when the other bolt sheered off it wasn't pretty.
Get a longer bolt of the best grade possible and use a dab of red loctite.
The shorter bolt could get you home in a pinch, but I would swap it as soon as possible. You need it to go all the way through the threaded hole.
ArtosDracon
08-08-2010, 10:40 PM
Yikes!
That's a :fingersx: and hope no one notices that your pants are wet when the car finally stops, type of situation.
dipren443
08-09-2010, 02:30 AM
To avoid any confusion with this info...
Grade 8 is a classification associated with SAE fasteners.
10.9 is a classification associated with metric fasteners. Metric fasteners have a higher strength classification available as well (12.9).
ArtosDracon
08-09-2010, 11:16 PM
Thank you for that, I had forgotten the difference was SAE vs Metric. Isn't there a grade 9 for SAE besides the ARP chromoly that's rated to 180K?
dipren443
08-10-2010, 05:19 AM
Yes, there is a Grade 9. They aren't very common, so I didn't even bother mentioning it. It isn't just for ARP. These standards are driven by SAE, but unlike Metric 12.9, SAE Grade 9 isn't very common.
If you had to have some Grade 9 hardware, I would look at aircraft suppliers.
