View Full Version : C5 brakes with year one snowflakes?
gmcdermit1
07-29-2010, 11:46 AM
I have looked through dozens of posts and cant find a definite answer on this. Do the 17" cast snowflakes clear c5 c6 brake setups? I bought the wheels and am just waiting on the back two to get widened and returned. I would like to start brake shopping but want to make sure they will fit. This seems like the way to go for big brakes on small budget!
Randy67
07-30-2010, 03:36 PM
They should work, they had a bit more room for brakes than my V45s had and they fit C5 brakes, needing just an 1/8" spacer to provide a little breathing room.
tellyv
07-30-2010, 05:49 PM
Yes they do I did it to my 78 ta.
gmcdermit1
07-31-2010, 04:32 AM
Did they need any spacers or anything? What setup did you use? Thanks
SLO_Z28
07-31-2010, 10:59 AM
The snowflakes have a ton of clearance. C5's are no issue.
gmcdermit1
07-31-2010, 11:22 AM
Thanks for the info!That's what I wanted to hear!
Henesian
06-10-2012, 11:05 PM
What did you do for wheel studs and lug nuts? Were you able to fit 1/2-20 studs and lug nuts in the bolt circle of those rims without any problems?
