View Full Version : LS1 Rear brake Wheel Clearance?
ryeguy2006a
07-23-2010, 08:58 AM
I am looking to convert to the LS1 Rear brakes with ebrake, and am wondering what the wheel clearance is on them? I want to run my stock 15" Ralleye rims on my second gen Trans Am. Will they fit?
Ryan
Apogee
07-23-2010, 10:14 AM
Won't fit. You can find some 16's that will squeeze over them, but 17's to be safe. Size-wise they are very similar to the 1997+ C5 rear disc kits, just with a deeper rotor offset.
Tobin
KORE3
Randy67
07-23-2010, 11:54 AM
The 98-up S10 Blazer rear discs will work with most 15" wheels and are similar to the LS1 brakes, just a little smaller rotor. You will need the 2wd rotors but can use the 2wd or 4wd backing plates/caliper mounts. There is more info on this on nastyz28.com, but I couldn't get the site to load right now.
ryeguy2006a
07-23-2010, 12:57 PM
That was why I asked, because I knew that the s10 rear disk conversion would fit under 15".
Thanks guys,
Ryan
