View Full Version : ATS oil pan relocation filter
67 ls1 vert
07-23-2010, 12:30 AM
using ATS oil pan with 2 AN#12 90's for use with a remote filter. What are you guys using for relocating the oil filter and what type are you using? Pictures please.
Steve1968LS2
07-23-2010, 05:59 AM
Canton makes a nice billet mount.. uses a rather large filter.
http://www.cantonracingproducts.com/cgi-bin/commerce.cgi?preadd=action&key=22-625
The offer a chevy filter as well, but the Ford one was reccomended as I recall
camcojb
07-23-2010, 06:52 AM
I used a CV Products remote mount. One thing I will say, use a high quality remote mount, some of the cheap TransDapt types are very restrictive.
I think mine was the CV745
http://www.cvproducts.com/Products.aspx?Search=remote%20filter%20mount
Jody
Steve1968LS2
07-23-2010, 06:55 AM
Jody
And use good fittings.. some fittings are more restrictive than others.
67 ls1 vert
07-23-2010, 10:17 AM
Thanks guys. It looks like the remotes have smaller ports than the #12's located on the pan. If I use the 1/2" remote I'll be okay? Just run a reducer at the oil pan and a #8 up to the filter and that will be big enough?
Yelcamino
07-23-2010, 01:30 PM
You can try this one like I got for my Chevelle...
The only problem you might run in to is it uses the "HUGE" HP6 oil filters.
Here it is side-by-side with a K&N HP-3002...
The opening in the middle of the big filter is 1.25" !
JeffT
07-23-2010, 01:35 PM
You'll need -12 x 1/2 npt adapters for the remote oil filter end and then run -12 hose from pan to filter adapter.
killer69
08-03-2010, 06:58 AM
We have now come up with a complete remote mount,filter and line and fitting kit. all black line and fittings billet filter mount and filter.
Also we have the line and fitting kit for the LS7 dry sump plumbing
"We" are:http://www.speedtech-performance.com/ I guess?
67 ls1 vert
08-03-2010, 08:22 PM
hey Blake, do you think you can give me a link to the kit you mentioned?
Thanks.
killer69
08-05-2010, 06:56 AM
i don't have a picture of it, if that is what your asking. i have a list of fittings and hose that i can supply if you need. call or email and i can get you the pricing.
