Results 1 to 6 of 6
05-11-2005 #1
unusual problem...need some advice.
I have been working with a friend's '91 Chrysler New Yorker-yes, no this is not pt material but I thought I'd share this for a fresh perspective. Let me first say I think the ECM is cooked but here's the deal: This car will start and run fine for about 10 minutes, thgen it dies-with power shut off to the fuel pump, ignition module/coil and fuel injector wireing harness. The car will sometimes start right back up for a few minutes then die again but most of the time it just cranks and cranks and cranks. Two codes were present in the computer prior to me taking battery out to be charged. One code was an under-charging condition and the other was a code for occasional over-charging...all of which is determined by the ECM because that is where the voltage regulator is present. I checked the coil, module, crank sensor, alternator (on and off the car), starter relay, and all was okay. Now's here's the strange part. If I do a voltagetest at the two battery terminals, I get 12.22V every time. If I probe the neg. terminal and the pos. cable itself, I get a reading of 220-230mV. WTF? There is a main disconnect between the positive cable and the lead into the fuse box and when I dis-connect that and probe the lead routing to the battery still I get a 12.22V read again. I connect it back to the lead routing to the fuse box and it reads 220-230mV again. And if I just leave the two cable hooked up to the battery, the positive side gets real warm.....strange. Any ideas? -Jabin
Gmachinz Sales and Performance
"updating the level of performance..."
[email protected]
*never argue with an idiot-they'll drag you down to their level and beat you with experience!*
