View Full Version : Question about turbo cam
powersstuntworx
07-18-2010, 01:37 PM
How would motor run without turbo while running a turbo cam?
camcojb
07-18-2010, 04:30 PM
it would run okay, certainly not ideal since turbo cams generally have less exhaust overlap than intake, opposite of a normally aspirated or blower cam.
But it would definitely drive down the road................
Jody
RSX302
07-22-2010, 10:15 PM
What is the cam specs?
Should run fine in a N/A set-up. Like Jody said, maybe not the best for top power. Your fueling will be the main issue. When I popped my turbo hose at the track, I was flogging a lot of fuel...
shmoov69
07-23-2010, 04:11 AM
Should run like a stock smogger small block IMO They are usually small with low compression. Should run fine if the timing is set for no boost.
68Formula
07-23-2010, 06:25 AM
Depends very much on the specs of the engine and the specs on the camshaft. The question is too generic to really give an accurate answer.
