View Full Version : Backspacing on 72 Pontiac LeMans
Brad1970
07-15-2010, 11:05 AM
SC&C Stage 2 up front, factory rear end. Front disc brakes, rear factory drums Vari Shock single adj all way round with SPC sport springs...
245/35 or 40 up front (maybe 255) & rear will be 275/35 possibly 295/35 depending...
18 x 8.5 wheel in front 5.5" offset
18 x 9.5 wheel in rear 6" offset
will that work?
or should I go with a 5" front offset & a 5.75" in the rear?
here is the wheel I'm looking at:
http://www.summitracing.com/parts/SUM-142-8961GM12/
http://www.summitracing.com/parts/SUM-142-8861GM20/
Thanks!
Brad1970
07-23-2010, 10:20 AM
Ok I've purchased:
18 x 8.5 with 5.5 bs front (back order from Summit)
18 x 9.5 with 5.75 bs rear
In a debate now...
Talking to Ponchopwr he says 18 x 8.5 with 4.75 on the front as that will not hit the front swaybar & that the 5.5" wheel will (he has a 70 lemans sport)
Roadbuster believes that 4.75 will give a more narrow looking wheel in the back than the front & should go with the 5.5 so the front won't look deeper than the rear. He owns a 68 GTO... He is also measuring his 17" wheels for me....
I GREATLY appreciate both guys for going ABOVE & BEYOND to help me out....
Anybody have thoughts on this issue?
724tim
07-23-2010, 11:09 AM
I have 17 x 8 on the front with 4.5" bs
17 x 10 on the rear with 4.75" bs
1971 olds cutlass 442
Brad1970
07-23-2010, 12:38 PM
Ok contacted Summit and changed the fronts to 4.5 bs... All should be well now...
NASH JUDGE
07-23-2010, 11:23 PM
your 5.75 bs will be perfect and you'll be able to run a large tire too.
