    Page 1 of 6 1 2 3 4 5 6 LastLast
    Results 1 to 20 of 109
      Dec 2009
      HOUSTON TEXAS
      stock subframe245/ 255s on first gen 335s on rear Road course performance
      Hey guys,
      I got a question for those of you with 245s/255s on the front of your 67-69 camaros and 335s on the rear. How competitive are y'all with the other cars with 275s on the front? I know this seems like an unfair question but what I mean is if you go compete in an event how much of a curve do you grade your cars performance by? I know it comes down to driver skill but are the cars with wider front tires beating the brakes off you or is the gain marginal at best.?
      Oh and how much do the 335s hurt you compared to 285s or some other tire due to front to rear ratio. I really like the look but how does it affect the way your car handles?
      Sorry for so many newbie questions but well I am a newbie!
      Dec 2009
      HOUSTON TEXAS
      C'mon guys somebody
      Henderson,NV
      I'd run a 295-315. To answer your question, the driver is the biggest piece to the puzzle in any of these events.
      Todd
      Dec 2009
      HOUSTON TEXAS
      I understand driver skill is key. What I am referring to is buget builds vs. Custom front subframes. How much difference did the wider tire make. How competitive can you be without coughing up the big bucks.
      Mar 2010
      Central IL
      You are asking a question that can't really be answered. Too many factors.
      Driver preference loose/tight, weight bias/distribution, spring rates, shock valving, etc. all effect the feel/balance of the car for all given variables.
      Rules of thumb (relative):
      more front weight bias bigger front tire
      loosen the feel bigger front tire
      heavier front spring bigger front tire
      harsher front shock valving bigger front tire
      etc. etc. I think you get the idea
      Once you have a package together you can get a balanced feel if you have a decent amount of adjustments built into the system and balance is the most important thing when it comes to speed.
      Will a bigger well balanced tire package always be better yes but you still have to be practical.
      MY philosophy use the largest practical tires you can and then adjust balance with spring rates (coil & sway), shock valving and tire pressure.
      The downside to a big front tire is the bigger you go the more numb and heavy the steering feel becomes.
      Sean
      The difference between stupidity and genius.... genius has limits
      Oct 2007
      I know what your asking.... and taking just the question your asking into consideration.. why no go 315/35/17 on the back and 275/40/17 on the front.... stock subframe....
      67 Camaro In progress
      Alabama
      Quote Originally Posted by 81S View Post
      There is virtually no instance where a smaller tire is faster. 335's will not make a car slower, ever! A bigger tire lets you adjust the car so that more cornering load can be taken by the rear. Yes, the smaller fronts will give up before the large rears, but that point will ultimately be higher than a car with smaller rear tires.
      It's the total grip available between front and rear that counts, and how you adjust the car to take advantage of it.
      Henderson,NV
      I have to disagree. Balance in a car is everything. I'm sure it could be made compliant but not as much as a better stagger.
      Todd
      Oct 2007
      Quote Originally Posted by Vegas69 View Post
      yep which is why i am thinking of the 315 over the 335... its a closer footprint front to rear
      Alabama
      Better stagger?
      The total traction available is increased with the larger tires. The rears can now carry more cornering load, and also have excess for acceleration. That is, you can tune the car so that it would have oversteer with smaller tires, in effect transferring load to the rear, but with the bigger tires the car is now balanced. Limiting your traction in an attempt to balance the car is a myth. The only reason to ever use smaller tires is if the ruleset you race under makes you.
      Aug 2006
      San Francisco, CA
      Whatever width you run, camber settngs will make all the difference. If you only give the car a token amount like -0.5, you'll only be using like 50 to 60% of your tire width anyways around hard corners. Just make sure you use what you got!
      Steven
      1968 Camaro: Project "TRACKDAY"
      Latest Track Weekend Video
      Build in Progress
      Henderson,NV
      Quote Originally Posted by barraza View Post
      Better stagger?
      Then why don't they run 450mm tire on a Z06? You can only transfer so much load to the rear tires especially on a nose heavy muscle car before it gets to loose. I'll take a fair balanced chassis from day one over making adjustments to make up for a compromise. That compromise being 100mm of stagger.
      I've run 255/345 and 275/335 combo on my car. I've also raced my car fairly extensively. A smaller stagger is easier to tune and will net you a more compliant car.
      Todd
      Alabama
      They don't use 450mm tires on a z06 because there is no room, and such a tire, if it existed, would be outside the "ruleset" of a production car, ie it would be a serious detriment because of it's weight. Remember, a z06 is a street car.
      What class do you race in?
      Aug 2006
      San Francisco, CA
      Barraza, I see where you're going with this, but I am hung up on how you can effectively tune understeer out with a huge tire mismatch....with that same "tune" being beneficial for the remainder of the lap that you're not steady state cornering. AKA corner turn-in, or accelerating out.
      If you have a significant tire mismatch (245f/335r) and you adjust your suspension so you don't understeer mid corner...that means you're trying to transfer A LOT more weight to the rear than is normal for our muscle cars. You're fighting a (presumed) 55%f/45%r weight distribution with a 42%f/58%r tire contact patch distribution. I would guess that your settings to get all that weight transfer mid corner would really upset the dynamics of the car.
      Porsche 911's, with like a 38%f/62%r weight distribution are the cars you'll find running massive stagger (235/315) or something like that.
      Steven
      Build in Progress
      Apr 2004
      OKC, OK
      To much stagger front to rear. Penny and OLC are both running 275/285 up front I think they both have understeer issues that had to be fixed with a rear sway bar. 245 would only be worse. The closer the stagger the easier they are to turn without adding in all the other factors.
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Jul 2007
      Olathe, KS
      From what you've stated, I get the feeling this will be more of a street car than track car. Honestly, how much time will be spent on the street vs track?
      If cost is a factor, and your driving time is biased toward the street, the stock sub can be made to handle very well. With a few more additional changes, and the right wheels, you can run 275's on a stock sub.
      Henderson,NV
      I run local SCCA autocrosses and just ran at RTTC at El Toro. Pick up a current Car Craft or Camaro Performers.
      Todd
      Alabama
      Quote Originally Posted by sik68 View Post
      You'll note that I never said the ultimate attitude of the car wouldn't be understeer, just that the understeer that you end up with will be at a greater total side loading, because you can transfer some load to the rear. With the added plus that you have more rear tire left for acceleration.
      Alabama
      Neat picture, but RTTC isn't really a racing series where you get the experience to optimize a chassis. In autocross, every bit of front tire you can get on these front heavy pigs is beneficial, but that isn't the rear tires fault either. Explain how reducing available traction at the rear makes the front understeer worse. Short answer - it doesn't. It's a myth.
      A chassis with 335 rear and 245 front would be better with wider tires in the front, but it won't be worse than one with 245 fronts and 315s in the rear.
      Rustburg, Virginia
      There was a thread recently that gave factory stagger ratios for various cars....I'll see if I can find it.
      EDIT: found the post that I was thinking of:
      https://www.pro-touring.com/forum/sh...7&postcount=22
