    Results 1 to 14 of 14
      Apr 2004
      Cedar Rapids, IA
      Sound deadening disappointment
      I know some of you swear by the sound deadening but I have to say I really can’t tell much of a difference. I used a high end DynoMatt equivalent and covered the whole interior. Drove the car with no interior, drove the car with just the sound deadening and drove again once the carpet was in.
      In all fairness this is a convertible with very loud strait through mufflers, so if it helped with road noise I would not be able to detect it.
      Lake Oswego, OR
      Dynamat only takes care of vibration and does not block sound. True sound deadening usually entails multiple layers of various materials.
      Lee
      1966 Cutlass
      The difference between truth & fiction: fiction has to make sense.
      Build Thread:
      https://www.pro-touring.com/forum/sh...ad.php?t=64470
      Aug 2008
      Pgh, PA
      Having driven my '66 GTO Convertible a bit by now, my experience is far different. 2nd Skin Damplifier Pro and Luxury Liner. 600hp motor, loud exhaust. Yeah, the exhaust is still loud, but the car itself feels "solid" and is much more pleasant. Even notice the difference just shutting doors, etc.
      '66 GTO Vert Project "Red Ink", 462ci of stroked pontiac power, TKO600, SC&C Stg II+, Tubular lowers, Currectrac Rear suspension, Moser 12bolt w/Truetrack, Wilwood Master and discs all around, too much fun for words...
      Apr 2004
      Cedar Rapids, IA
      Quote Originally Posted by wmhjr View Post
      I would knock on the panels with each sheet I installed. To me the difference was slight.
      Aug 2008
      Pgh, PA
      Interesting. The difference to me was the difference between a kettle drum and a solid object. Did you put the stuff everywhere? I put damplifier Pro in the doors, quarters, wheel houses, trunk (everywhere) firewall, floors. Covered everything pretty much. Then Luxury Liner Pro on Firewall, floors and trunk. I now have zero vibration sound or "echo" kind of sound. Close a door and it's SOLID. Night and day difference.
      Auburn, WA
      I would think there would be less of an improvement in a convertable, where most of the noise is carried in through the top, instead of the bottom.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Nov 2007
      Lafayette, LA, USA
      Quote Originally Posted by rohrt View Post
      What is a "high end Dynomat equivalent? I am no expert but from what I have read here there is a big difference between brands.
      Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting - Holy cow - what a ride!!!
      See my build
      Jason
      Aug 2008
      Pgh, PA
      Quote Originally Posted by silver69camaro View Post
      You're somewhat right. If you're trying to eliminate exhaust noise from a relatively loud exhaust, it's gonna be tough. But road noise, vibration, and "echo"? Big difference there. I mainly hear my exhaust (which is a bit loud) but not road noise or rattles. You'll never make a vert as quiet as a coupe. But it's worth the effort to try.
      Apr 2004
      Cedar Rapids, IA
      My exhaust dron is from 2200-2800 and is obnoxiously loud. I post this to only serve as a warning to others that if you expect the exhaust noise to quiet down, it won't. Road noise or vibration rattles I believe, just can't tell at this point.
      I'm getting old so bought a set DynoMax mufflers that I plan to throw on the car. I just won't have a reference for comparison like I did before.
      Aug 2008
      Pgh, PA
      OK, so it's really not overall sound deadening performance you're unhappy with, but the ability to remove exhaust drone.....
      Different story. I'm not sure anything other than ear plugs can help if you have really persistent exhaust drone. There is also a difference between trying to deal with "exhaust noise" and "exhaust drone". Very different animals.
      Jan 2010
      Delaware
      Yes, there isnt a thing thats going to get rid of the exhaust drone on my Spin Tech mufflers between 2100 and 2600 rpm. At those rpms they resonate. Switching to a different muffler can help. I'm going with a set of Goerlich Xcelerator x123's on mine....which is moving up from a 14" to an 18" muffler, has been shown to reduce about 10 db from what I have and NO resonance from what I've been told. All in a muffler thats been tested to flow 99% of what free pipes flow. Hope its all true...lol
      1973 Trans Am 455 SR block, ported 6x-8 heads, solid cam, Victor intake, 830 CSU carb, aluminum rods, 77mm Garrett turbo and methanol injection. 1064hp at the flywheel@5500 rpm
      Nov 2007
      Phoenix AZ
      When it comes to noise reduction in automobiles, there are 2 tyeps of sound deadeners that are commonly used:
      1. Constraint layer Dampers - Foil backed mats with elastomeric adhesive similar to the Dynamat Extreme you are used to. These vibration dampers reduce structure borne noise, (vibrations) and to a degree, reduce some heat and make the car feel a bit more solid. This is always the foundation layer of any automotive insulation project.
      2. Noise Barriers- these are usually mass loaded vinyl or lead sheeting laminated to a foam decoupler. These go on top of the vibration dmaper to block the transmission of airborne sound waves.
      Many company advertise that their vibration dampers will lower road noise and exhaust drone by 20 db or more. This is crap.
      VIbration dampers reduce vibrations. That is about it.
      The barrier does the grunt of the work on airborne noise so it should be the hero. Not the damper. Dampers however are very improteant and will, on theri own make a very noticable impact on noise levels and comfort levels.
      Dynamat Extrme is a good product for what it is, but it is pretty expensive
      There are lots of comparable products out there tha cost less, and some, that are much better than Dynamat Extreme, and still cost less.
      I am not here to spam the board, so if anyone has any specific questions about our products, go ahead and ask.
      Hope that helps!
      ANT
      Jun 2001
      Newbury Park, CA
      Where does the exhaust exit? Full tailpipes that exit straight back will help. Big engines, big cams, big exhaust tubing, ineffective small mufflers, and turndowns will always be loud no matter what other barriers are put in place.
      Using the largest possible effective muffler is important. I've had good luck with Dynomax Super Turbos on several builds. Dynomax also makes a larger version 3" in/out that works well.
      Sep 2004
      Vacaville, CA
      X2 on the DynoMax Super Turbo's!
      Tim
