View Full Version : Dies under hard breaking
GRNOVA
06-06-2010, 03:06 PM
What would cause the engine to die when braking hard in the corners on an auto cross. Every time I come into a turn hard and slam on the brake pedal the engine dies. Roots blower, manual brakes, and carbed.
https://static1.pt-content.com/images/pt/2010/06/IMGP0809-1.jpg
chr2002ca
06-06-2010, 03:11 PM
I'm not sure if you're using vacuum advance, but I noticed this exact same problem when I had my distributor vacuum advance hooked up to the carb vacuum port. I then changed it to run off the intake manifold port and the problem went away completely.
GRNOVA
06-06-2010, 03:12 PM
No vacuum advance. Locked out Msd billet dist.
shmoov69
06-06-2010, 04:06 PM
Fuel slosh from the vent tubes on the carb IMO. Holley makes vent extenders that go inside the bowl area to keep that from happening. Not sure what they are called tho. I'll try to find them.
Edit:
found them. Vent whistles
http://www.oreillyauto.com/site/c/detail/HOL0/2689.oap?mc=HOL&mn=Holley&pt=N1277&ppt=C0261
And some tech for that problem:
http://classicbroncos.com/carb_tricks.shtml
06-06-2010, 04:55 PM
yep, or the float levels are just too high.
wicked68
06-07-2010, 05:03 AM
what do you have your idle set at? for competition you will need to run it at 1000 - 1200 600-800 is too low and will let it die
GRNOVA
06-07-2010, 05:05 AM
Between 600 800
wicked68
06-07-2010, 09:41 AM
Between 600 800
I would recommend you increase this to 1000
