View Full Version : GM A Body Swap ????'s
mrgto
06-04-2010, 04:49 AM
1. Which Oil pan did you use?
2. Which front accessories did you use with AC?
I'm planning on installing a '04 LS1/T56 out of a GTO into my '66 GTO. Thanks.
wmhjr
06-04-2010, 05:34 AM
Maybe talk to these guys...
http://www.southernperformancesystems.com/a-products-brp.html
Just remember that though it's close, a GTO is not a Chevelle. You might expect some differences in the front steering as well as some other minor stuff. Shape of the front wheel wells, etc. There isn't THAT much different for what you're doing up front, but there is some.
mrgto
06-04-2010, 05:49 AM
I'll give them a shout, thanks! :)
dhutton
06-04-2010, 07:30 AM
Do a search for a build thread by b-man. It's a 64 but very detailed and worth the read.
1badchevelle
Have you gone to LS1tech.com you will find all the answers to the questions you dont have.
mrgto
06-04-2010, 07:49 AM
I know B-Man and I have been on Tech....just trying to cover all my bases.
dhutton
06-04-2010, 09:51 AM
I am thinking the new cast pan from MAST will be the one to use on my 64 GTO due to it's shallow depth at the front. Rumor has it that it will be out this month.
http://www.mastmotorsports.com/2010/product-view.php?cat=Oil%20Pans&id=160
The WidowMaker
06-04-2010, 10:20 AM
wegner front drive and autokraft/champ pan. pan clears the tierods because i raised the motor to gain ground clearance so i could then lower the whole car a little more.
